Old 24-02-2010, 10:22 PM   #1
WOTDAH
Yes YOU
WOTDAH's Avatar
Default Supply issue stops production at Broardmeadows
Production has stopped and production workers have been stood down until Monday due to a supplier issue. A small component in the aircon unit is faulty, not know how many cars have been built that are affected
WOTDAH is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2010, 10:27 PM   #2
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
So a crew will go back and change out parts on a few hundred vehicles?
Sounds like fun.....
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2010, 10:27 PM   #3
XR_6falcon
that small component i think is the HIM modual. Ive seen about 20 FG XR6's (and counting) that the A/C unit not working.
Big dreams, not enough money
Smoke tyres, not drugs
XR_6falcon is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2010, 10:30 PM   #4
4Vman
4Vman's Avatar
Ouch... hate to be that supplier.... its expensive to stop the line....
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2010, 10:31 PM   #5
Smoke Pursuit
Theres a few late 2009 FGs with aircon problems, i wonder if its the same thing.. 12th month plated im told.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2010, 09:24 AM   #6
WOTDAH
Yes YOU
WOTDAH's Avatar
The problem is a faulty 20c component within the HIM. EVERY Falcon and Territory since November is affected (that's roughly 15000 cars). Takes upto 4 hours to replace the faulty part as the dash needs to be removed. I smell alot of bad publicity for Ford
Old 25-02-2010, 10:11 AM   #7
charles_wif_xf
Purveyor of filth
Oh boy! Whats the actual fault cause mine is a December 2009 build?
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2010, 10:20 AM   #8
HSE2
7,753
HSE2's Avatar
Potentially, for some customers, that is the worse sort of failure. Once you start pulling interiors to pieces they have a nasty tendency not to go back the same way. Also risk of damage to surrounding areas.
This sort of stuff can happen at any time.
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin'
HSE2 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2010, 12:12 PM   #9
Bundy
All Ford Club Life Member
Bundy's Avatar
Yes had a mate with a brand new top of the line VP Calais at the time, had warranty work that needed his dash removed, needles to say it went pear shaped quicky with more rattles afterwards and dirty marks, scratches and gouges from the removing / installing part on other interior components. Took him about 3 months but he finally got it sorted when HQ had a talk to the dealer prinicple.
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2010, 02:02 PM   #10
Silver Ghia
Silver Ghia's Avatar
IMO depends alot on the capability of whoever does it. I had the HIM shaft break in my BA Ghia a few years ago, dash out job, fixed under warranty by the dealer and no problems or rattles whatsoever since then.
I'm sure there will be some who will do sloppy work, hopefully Ford will have ways of avoiding that happening.
Otherwise its not an issue really, as long as they have a good long term fix for the problem.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 25-02-2010, 02:11 PM   #11
jcxr
Tribal Elder
jcxr's Avatar
Seeing as they have quite a number of vehicles to repair it would be better if they had a crew that just went to dealerships and specialised in this repair only, not letting any technicians learn on the job. The crew would know it backwards and do the job in half the time without damaging interiors etc.
jcxr is offline   Reply With Quote Multi-Quote with this Post
