12-02-2010, 02:10 PM | #1 | ||
Critical Thinker
There will come a time where my trans will need upgrading or rebuilding.
Does anyone know if these transmissions can be strengthened, or rebuilt to handle more power, OR if it would be better just to ditch them for something that came out of a different car. i.e. XR8, turbo trans or whatever.
12-02-2010, 02:14 PM | #2 | ||
haha... ask stav this question
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
12-02-2010, 02:20 PM | #3 | ||
Critical Thinker
LOL. I knew his name would get mentioned... :P
12-02-2010, 04:29 PM | #4 | ||
MGA Automatics Ask for George an absolutely magic bloke comes highly recommended.
Just re built my BTR and a Tranny cooler drives like the day Ford made it. HAs been in business for over 30 years. 02 9790 31 33 59 Hoskins ave Bankstown, over and Out Vadim
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
12-02-2010, 05:01 PM | #5 | ||
Just slidin'
Stavs only good at breaking them, not getting them built.
There are places that do them properly, not just a slap together "built" job. They can go up to about $3500 in price though.
MD Mondeo - For the family
12-02-2010, 05:11 PM | #6 | ||||
Captain Malcolm Reynolds
With your car Shav, you should just bite the bullet and try do a full ZF conversion ;)
If that's even possible to fit a ZF into an AU.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
12-02-2010, 05:31 PM | #7 | |||
Critical Thinker
12-02-2010, 06:19 PM | #8 | ||
Just slidin'
Maybe a C4 instead if you wanted to stick with the auto?
12-02-2010, 06:41 PM | #9 | ||
Critical Thinker
only if it was an AOD C4.
Are the V8 BTR's stronger than the 6's?
12-02-2010, 07:12 PM | #10 | |||
Performance Inc.
The BTR's in the TE3's were modified and strengthened by tickford for the 250kw motor if you dont need one yet keep a look out for a wrecked T3 or P250 ute they come up occasionally and not near 3.5k. Not too much trouble with them in the t cars so you should be right.
In The Garage... FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
12-02-2010, 07:27 PM | #11 | |||
Critical Thinker
12-02-2010, 07:47 PM | #12 | ||
Smile
Well my new box is clunking again so not the guy to ask... Despite what people say no the ford 4 speed is a lost cause as far as I understand. 1st gear engages the use of the sprag only and this results in more failures because the other clutches are not engaged behind it to give it strength..This is my 5th gearbox now and can honestly say that its been babied yet this is clunking tooo..If this goes then I may get something better. I had kvlar bands..super clutches and it didnt make a difference to the strength for me it lasted less than a second hand box...
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
12-02-2010, 08:07 PM | #13 | |||
Stay Classy ™
I would like to see what the limits of the T3 boxes are, someone correct me if I'm wrong but there was a slight change to the S5 solenoid which firmed up the shifts and also another adjustment to another solenoid for it to hold gears when using the ESS, but apart from that they remained the same as any other BTR 4SPD you would find in an XR8. |
12-02-2010, 09:00 PM | #14 | ||||
Performance Inc.
Maybe Tickford did something different to prodrive FPV? as when you ask about reliability in the Tseries autos not too many reported as failed. You are correct about valving mods or adjustments to firm up and hold gears this was needed for ESS to work effectively (flappy paddles) also IIRC a cut out was used to save the box too much distress during flat out changes and Im sure I read somewhere about bearings either wider or doubled on shafts or that could be the onset of oldtimers Hows that sweet T3 fairmont with all the best T series options going?
12-02-2010, 11:47 PM | #15 | ||
Now Fordless
Before the ZF came out, there were a few heavily modded XR6Ts running the BTR box. I remember reading somewhere that 4th gear wasnt that strong so one of the tuning companies was using it as a 3 spd.
12-02-2010, 11:52 PM | #16 | |||
Back to Le Frenchy
Nothing wrong with the BTR, mine lived behind the 347 for a long time and I never had a problem with it.
It all comes down to how it's driven and if built, if the bloke that did it actually had a clue.
13-02-2010, 12:17 AM | #17 | ||
Stroking it...
I agree with RG, there can be good and bad.. My box has lived through a lot of abuse behind my stroker, with plenty of abuse! But in Stavs case he has managed to kill several boxes with a lot less power. Just like RG's block ended up in 2 piences whereas mine and others have held together! If your playing with stock parts (be it bottom ends, gearboxes, diffs etc) then things are going to break on occasion!
I think if your going to wind up the S5 solenoid and make it shift realllllly hard on a stock box, then yes, things are more likely to break.. But to the OP's question, better clutches, and kevlar bands will lengthen the life of the box, as long as it is built properly. I did have the specs of the minginator gearbox somewhere, now there's a built BTR!
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
13-02-2010, 12:20 AM | #18 | |||
Stay Classy ™
13-02-2010, 02:18 AM | #19 | ||
Critical Thinker
Thanks lads. I guess its a matter of trial and error. I dont pull burnouts, but i do like to hold the gears till redline and also manually change down down gears in the hills. I know that driving style isnt the best for the box. I have an adjustable shift kit fitted as well as a hd trans cooler. I just want a box thats going to take regular manual shift and hard acceleration i give.
13-02-2010, 05:03 PM | #20 | ||
ring mv automatics. Theyre fairly local to you I think. 600hp box for less than 3k I believe. dont forget anything that comes out of a v8 will need the input shaft changed
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
15-02-2010, 11:39 AM | #21 | |||
Critical Thinker
15-02-2010, 12:04 PM | #22 | ||
That was the price that I got for a v8 box I got but there probly no different
15-02-2010, 05:59 PM | #23 | |||
RIP...
Good aftermarket ones are typically quite a bit better than what Ford come up with.
. Oval Everywhere... |
