Old 04-01-2010, 10:07 PM   #1
spi1
Default Focus LS fiasco-now petrol fumes
OK. I've posted a few threads here!
the saga began when the car wouldn't start.
Mechanic changed fuel pump relay switch.But no luck!
Mecahanic lowered the fuel tank to check the fuel pump.It seemed Ok.
He called an Auto electrician who found some bad connections in the fuse box. He fixed that and changed a faulty petrol cut off switch. It worked!!!
All runs well!
But I now get a fuel smell just behind the back wheel on the drivers side, which makes it's way into the cabin.
What could that be? I can't see any fuel on the ground! just a smell! Could it be badly clamped hoses???
Thanks!
From dissapointed ford focus owner!
spi1 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2010, 09:04 AM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Would help if you kept this all in the same thread, as it is hard to help with tiny bits of information.
Don't know on this one. Obviously to do ith the petrol filler or tank, given its location. Is it all the time, or only when you fill up?
Old 05-01-2010, 10:40 AM   #3
spi1
Default No smell this morning!
Actually it was when I filled up on a hot day with Unleaded 95. I just drove it this morning, fairly cool and no smell!
Old 05-01-2010, 10:57 AM   #4
melbzetec
melbzetec's Avatar
Try not filling the tank completely. You may be over-filling the tank, and getting some excess venting
Old 06-01-2010, 11:02 PM   #5
spi1
Ok! Mechanic tightened some hoses and said something about an overtight O-ring. But things seem back to normal!
Old 07-01-2010, 09:40 AM   #6
Fredo
Nice kitty . .
Fredo's Avatar
Glad to hear it is fixed mate.
Keep in mind your experiences might be what someone else is having so please share them in the LS Fault Register
Fredo
Just remember, amateurs built the Ark and professionals built the Titanic!
Late 2005 LS CL, 5spd Manual, 5 Door, Titanium Grey
To Do List:-
:- Using 95 RON Fuel (DONE -easiest upgrade of all) :- XR5 Springs (DONE) :- Lower air box removal (DONE) :- K & N Panel Air Filter (DONE)
:- 2.25" Cat Back (DONE) :- DBA Brake upgrade (DONE)
Fredo is offline   Reply With Quote Multi-Quote with this Post
