Old 11-08-2009, 11:44 AM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Wireless network help
Guys
having a bit of an issue with my home network at the moment. Is a standard Telstra one, all works fine etc but it seems that the connection is resetting/not going through on sites and programs that require logins, examples being Ebay, Itunes istore, hotmail etc - I go to sign in and they just will not load up and fiefox tells me the connection was reset. The weird thing is though that everything else is working fine - forums etc all ok.
Any ideas on what I might need to change?
RAM 1500
Old 11-08-2009, 11:48 AM   #2
XR8 Uterous
It's the iphones fault.
XR8 Uterous is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 11:54 AM   #3
RG
Back to Le Frenchy
RG's Avatar
Is it a NextG set up?
Old 11-08-2009, 12:28 PM   #4
ch33z1l
Dawn
ch33z1l's Avatar
Do you get the same message using IE?
Update IE and FF to the latest releases...
You can also try disabling the local area connection (Control Panel, Network Connections) and then re-enabling it. Right clicking on the LAN connection will bring up the option to disable it.
Also try disabling any add-ons for the time being, as these can sometimes be an issue.
Clay
ch33z1l is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 12:36 PM   #5
RG
Back to Le Frenchy
RG's Avatar
Actually, have a look at your anti virus and firewall settings.
Old 11-08-2009, 12:43 PM   #6
Cadge
When it resets, do you notice if the lights on the modem go out? in particular, DSL, Sync or link light?
If the internet is actually dropping out, then the above will only be a temporary fix.
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 12:48 PM   #7
ch33z1l
Dawn
ch33z1l's Avatar
Also try the usual refresh and cache cleaning.
As all of the sites mentioned use SSL encryption, it possibly could be that FF has its cypher strength set to 0 instead of 128. (this is a common problem with IE).
Check the advanced settings in FF. Under encryption, make sure 'use SSL' is enabled.
Thats about all I can think of atm
Old 11-08-2009, 01:05 PM   #8
Teflon Turbo
to see if you have internet connectivity
start > run > type cmd >type ping yahoo.com
you should get some data replies
Teflon Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 01:23 PM   #9
b2tf
b2tf's Avatar
Yes, the following comes up:
Reply from 69.147.114.224: bytes=32 time=301ms TTL=47
Reply from 69.147.114.224: bytes=32 time=299ms TTL=47
Ping statistics for 69.147.114.224:
Packets: Sent = 4, Received = 4, Loss = 0 (0% Loss)
Approximate Round Trip times in milli-seconds:
Minimum = 299ms, Maximum 301ms, Average = 300ms
The modem does not have any lights go out etc - the network appears normal, the laptop tells me the connection is excellent etc but I cannot get these sites to load.
Russ i dont think it's nextG, its just the standard Telstra Broadband wireless ADSL modem.
All browsers are updated and firewall is on medium-high setting.
RAM 1500
Old 11-08-2009, 01:28 PM   #10
RG
Back to Le Frenchy
RG's Avatar
Firewall being on medium-high will be the issue I think. Try dropping it to med-low and trying again.
Old 11-08-2009, 01:34 PM   #11
b2tf
b2tf's Avatar
Just turned it right off and tried - no change.
RAM 1500
Old 11-08-2009, 01:38 PM   #12
greens_tuf
greens_tuf's Avatar
What sort of router are you using?
There is a field called MTU setting, this should be set to 1500 or you could try auto.
Check it out and let me know.
greens_tuf is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 02:38 PM   #13
ch33z1l
Dawn
ch33z1l's Avatar
Some other ideas:
Ensure 'work offline' is unticked. (File>Work Offline).
Temporarily disable antivirus.
Reboot computer
Contact Telstra. Possibly a DNS issue at their end.
Old 11-08-2009, 03:14 PM   #14
Teflon Turbo
do you have the latest java updates?
when you go to the sites in question and i know it sounds stupid but hit the reload or F5 furiously
Old 11-08-2009, 10:00 PM   #15
b2tf
b2tf's Avatar
I've been unable to find the MTU setting, any ideas of where I would find it?
I also updated Java this afternoon and now ebay and hotmail work, however carsales.com.au doesnt (sorry, just naming sites that dont work so hopefully we can resolve this). I have checked the antivirus and all seems ok but it does seem like the wireless network is timing out/going inactive after a period of time while still saying it is connected.
Thanks for the help so far guys, any other ideas on what I can try?
RAM 1500
Old 11-08-2009, 10:06 PM   #16
Teflon Turbo
sometimes you can ping a particualar site to see if they are working too and how slow they are. at the time of this post i pinged carsales.com.au and there was a time out which means to me they are having issues.
Old 12-08-2009, 08:22 AM   #17
Teflon Turbo
i forgot to say that sometimes it times out too because their security measures are designed that way to prevent attacks
Old 12-08-2009, 08:55 AM   #18
duaned
duaned's Avatar
No the Maximum Transmission Unit for ADSL shold be set at 1492. 1500 is fine for cable etc.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2009, 09:35 AM   #19
red_hotxr6
red_hotxr6's Avatar
I have just started experiencing this similar problem with mine as well. I have a 3g connection. The modem will stay on like its connected but my windows live/ msn messenger just goes offline...i can get on to internet explorer but those 2 stop working.
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
