Old 16-12-2008, 02:56 PM   #1
needhelp
Default pls help, auII 4.0ltr yellow BCM i have no injecter pules
i have spark, crank and fuel pump but no injecters????? can any one help
needhelp is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2008, 03:46 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Your first step should be to explain WTF you are on about. Then we can help.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 16-12-2008, 03:57 PM   #3
bodes-sh
he has a thread further down the page in ford 6's i think. he has put this motor into an f truck and has no pulses to start the motor.
you need to have the ignition barrel from the car you got the bem out of as well as the sensors for the chip inside the key. depending on where you are, you may be able to get the car towed to a tuning workshop and have the security disabled, this then enables you to use the motor and ecu without the smartshield security setup. i know BPT in perth have the ability to disable the security measures in au and ba ecu's
Old 16-12-2008, 06:35 PM   #4
The Monty
Just slidin'
The Monty's Avatar
Oh, ok, that makes alot more sense. Unfortunately I have no Idea how to fix it, so listen to bodes-sh.
