Blue Power Racing Developments The home of Blue Power. Website Link |
03-12-2008, 02:27 PM | #1 | ||
[img]https://[/IMG] [IMG]Have you heard any bad reports about extream clutches : as i am replaceing the 3rd one in a few day time
03-12-2008, 02:40 PM | #2 | ||
driving habits?? I find them better than exedy in my other car, and I used to ahve issues with wearing them out pretty quickly
2009 FG turbo ute 1983 Toyota sprinter- quick/fun car with a Nissan heart 2010 CRF250- when I want to get dirty |
03-12-2008, 04:38 PM | #3 | ||
this has only done 2000k i had a hd put in and failed parts of the clutch plate let go
and i was getting bad vibes and had taken it out after 600k and found 3 big hot spots on the flywheel and pressure plate ? and put it back in and 1000k later it was un driveable and extream said it wasnt runn in ? they gave me a ceremic one to place in as they asked the rwk of my car was 280rwk they said that it would fix it and now its undriveable as trying to take off its impossible and just waiting for it to rip the box out and break the engin mounts trying to take off as the shudder is that bad |
03-12-2008, 06:03 PM | #4 | |||
Reaching for 200...
Peter. Ph: (02) 9606 9666 Most who drive V8's both Ford and Holdens will swear by them.
Tuddy's XR6 04' BA XR6 - Blueprint - 6 Speed with Rip Shift - HD Clutch 2.5"/BFGT Exhaust System with Quad Tips - 4490's Extractors 19" ROH Flares - 20% Underdrives - Interior Colour Coded - Sunroof - BOSS Bonnet Stage 2 Crow Cam's - Crow Cam's Valve Springs - BPR Airbox M86 LSD Diff with 4.1s - Upgraded Brakes with Slotted DBA 4000's Leather Interior - Rear Power Windows Projects Underway: Sound System |
04-12-2008, 03:56 AM | #5 | |||
Location: Working, chasing after my daughter and working
I worked out that they dont like alot of heat onto them when the clutch was cold, I use to have to ride the clutch a little bit before my first pass otherwise on the launch it would crap it self first pass of the day. Bacically found them to be total crap, didnt have a good experience with them at all. Now have a Textralia twin plate, been fine for a while now, you be sweet with one of there single plates. If I was you I would give Peter a call from Textralia good guy and will look after you. |
04-12-2008, 04:45 AM | #6 | ||
Force Fed Fords
I had the misfortune of owning an Xtreme brand clutch in my last Turbo. Lasted about 4 months and 1.5 runs on the qtr mile.......Was terrible to drive with. I did go a Tex twin plate, awesome to drive, but the noise when engaged was quite frankly unacceptable. I do believe they are quite good in the single plate set up for the V8s though, so you should be fine.
2021 Focus ST-3 Mountune Enhanced |
04-12-2008, 12:47 PM | #7 | |||
Bear with a sore head
04-12-2008, 01:42 PM | #8 | ||
KenneBell Australia
We dont use nor recommend extreme clutches.
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
04-12-2008, 05:36 PM | #9 | |||
Force Fed Fords
04-12-2008, 06:43 PM | #10 | |||
Ive tried a few of Tex's single plates, great clutch. |
04-12-2008, 12:34 AM | #11 | ||
Go straight for a Tex, you wont be disappointed with one
04-12-2008, 07:22 PM | #12 | ||
Broken
Hi guys, genuine question - exactly what has failed on the stock clutch set up?
Reason I ask, I ran the stock set up in my BA for over 120k, done maybe 250 laps of the circuit, and in my current GT, would be very disappointed if it won't last 100k. And it will do as many laps as the XR did, but with a fair bit more power. I'm just intrigued how you guys kill them. Is it from riding them away from the line, or just pulling burnouts? cheers
The Scud GT 11.4 @ 128, 1.88 60ft. |
05-12-2008, 09:42 AM | #13 | ||
The problem with my standard clutch was that on the strip the first pass it would be great and go to do a second run and just slipped and it wouldnt get any purchace on the run so i decided to get a extream clutch and then even more trouble so peter from Textralia said he will fix their crap
04-12-2008, 07:28 PM | #14 | ||
BOSS 5.4L Enthusiast
I know when dad replaced his in the Pursuit it was from Clutch slip, wasn't like the thing was free revving after a gear change but once the clutch went in there was a difference..
They Run an Extream in their Pursuit, can't say i like it, they are used to it, but i think after i get a Tex and give them a drive they may change over. |
04-12-2008, 10:17 PM | #15 | ||
KITTY Crew Member
My 800hp Tex single plate is getting along nicely. Just a small bit of shudder left after about 1200km. But when you want to just GO she grabs and goes hard. Very nice so far. And no rattle
FOR SALE BAII Super Pursuit 0083 Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
05-12-2008, 10:29 PM | #16 | |||
John, what spec did you end up going for?
2015 FGX XR8 5.0 S/C 645 RWKW |
05-12-2008, 10:34 PM | #17 | |||
Clevo Mafia Inc.
How do you think it would hold up dropping the clutch with slicks on ? |
07-12-2008, 06:48 PM | #18 | |||
The best thing with the Tex clutchs is you can ride the clutch off the line without worring about cooking the clutch, they can handle constant back to back passes where others have to cool before runs. |
07-12-2008, 07:37 PM | #19 | |||
HO INTERCEPTOR
Cheers Glenn
Lightning Strike, BF, 6 Speed Manual, XR8 Ute. Stuff to make it GO by BluePower Racing Developments ....Speed is a byproduct! Body and Visual by HO My Business GutterGuardGuyAluminium Guttermesh Supply & Installation. OrsmFordCruisers R.I.P Wayne Draper
08-12-2008, 11:40 AM | #20 | |||
5.4L V8
I had the same clutch in my car before I swapped to an auto,they are tough as nails, but pricks of things to drive I found. |
08-12-2008, 01:08 PM | #21 | |||
HO INTERCEPTOR
Cheers Glenn
06-12-2008, 03:05 AM | #22 | |||
Dose the shudder go completly with this set up (Tex single plate). Mine seems to be getting better and I seem to be getting smarter with it but it seems like a lot of effort in getting it just right on take of normal driving. Hard work really, When she is cold it takes of like a gem but when the clutch warms up it shudders. I love the clutch and happy with performance but I don't like that shudder, as I said it does seem to be better. I also notice a loud knock seemingly from the right hand side and I am thinking it is the big fat Difallipo dual tail up over the diff. Needs some fine ajustments to fit it iin better maybe. |
05-12-2008, 10:46 AM | #23 | ||
KITTY Crew Member
Peter from Tex is a top bloke, and delivers what he promises. (A nice clutch)
09-12-2008, 12:56 PM | #24 | ||
KITTY Crew Member
Mine is a if you dont drive it properly from take off. Sometimes I get slack, she gives me a shudder and I panic and try and give it a few revs. With 400kw I have almost wheel standed onto the boot in front of me.
But I like the clutch, its tough and it does what its meant too. Just some more driver education required.
10-12-2008, 12:53 AM | #25 | ||
Cat be Still !!!
I had an extreme cushioned ceramic in mine but it developed a vibration around three grand and gone by say three and a half. and shudderd till ya fillings fell out on take off.
Got a mate to pull it out, On close inspection looked like the spline was out of wake with the clutch disc, Put it down to the peanuts that fitted it didnt have an alignment tool and forced the gearbox into the disc spline, Anyway's they replaced it foc but just to be on the safe side because of the shudder i got them to give me a high burst organic plate. So far so good, Have done heaps of runs since. Have also done a few stand start 2nd gear burnouts. Leaving behind two nice black strips half way up the street. PS, Can anyone tell me why i have to back out the adjustment every few months. |
