Old 30-05-2008, 02:56 PM   #1
dunlopgrant
Default Dont know
Hi everyone i am new,can someone please diagnose this problem
au11 cant open boot or activate central locking ,have put new battery in ,maybe bcm?
dunlopgrant is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2008, 07:27 PM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
You need to re-program the remote key fob... i'm sure one of the boys here knows the tutorial link.
Old 04-06-2008, 05:35 AM   #3
seduced_xr
BF XR6
seduced_xr's Avatar
should be the same on all falcon
this is process for ef el ba and bf so should be au aswell
1. Obtain a remote (can be a second hand one - they can all be reprogrammed, or you can buy a new one for about $90 from Ford).
2. Close the doors.
3. Turn the ignition key to the accesories position.
4. Within 5 seconds of turning the key, hit the rear demister button three times in succession.
5. The door locks will cycle once to indicate the special mode has been entered.
6. Press any button on the remote you wish to program.
7. The doors will cycle to indicate a new remote has been programmed.
8. Continue steps 6 and 7 for all remotes (including existing ones) you intend to use on the vehicle.
9. When you’ve programmed all the remotes, turn the ignition key off. The doors should cycle again to indicate the programming session has been completed.
seduced_xr is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2008, 09:54 AM   #4
TOASTED
JMM modded EF
someone stick this
Originally Posted by ILLaViTaR
Guess the alcohol tax is turning people to mind altering drugs.
I drive : A heavily modified EF Fairmont with a JMM dev5 cam, worked head, 3.5" mandrel bent intake, exhaust, and a few other bits n pieces like a stally etc.
"She goes like a zirtek"
WANT A FAST FORD RING THIS BLOKE V V
Abbott Engines for HeadWork
20 years experience
PH Rob on (07) 5526 3883
TOASTED is offline   Reply With Quote Multi-Quote with this Post
