Old 20-04-2008, 08:49 PM   #1
vflynn
Default Door alinement EL
Hi can anyone help me out the driver door on my el has droped about 1/2 inch and I am having trouble shuting it have to really slam it can some one tell me which bolts I have to loosen off to realine it.
cheers
vince.
vflynn is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 08:55 PM   #2
Serial_Fool
Whipper Snappa
Serial_Fool's Avatar
Sounds like a door hinge has been bent.
Fully open the door and you will find some hinges between the front door and the fender. The bolts are 10 mm I think.
*insert witty quote*
Serial_Fool is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 09:03 PM   #3
Nikked
Oo\===/oO
Nikked's Avatar
If you can wobble the door up and down its' most likely a worn out hinge, it's a common problem.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
