Old 25-12-2007, 10:04 AM   #1
Aldo
Aldo's Avatar
Default best of 13.3 at 109mph
Hi guys,just looking to see what time i should be able to achieve with this sort of mph.I was stalling it up to 1200rpm and was a bit slow off the line,i figure next time i head out i'll just give it 1800-2000 or whatever i makes it squat for take off......im hunting a 12 before i swap ot the diff gears to 4.11s in the new year.
cheers
aldo
oh and merry christmas
Xw ute
Toploader
Aldo is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2007, 03:03 PM   #2
Falc'man
You dig, we stick!
Falc'man's Avatar
There's definitely a 12 there with a good launch. What was your 60' time?
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2007, 10:09 PM   #3
Aldo
Aldo's Avatar
i managed a 2.1 60ft,good or bad? It was my first ever outing.
Xw ute
Toploader
Old 25-12-2007, 10:50 PM   #4
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Not to bad especially for first time out, if you have a std stall convertor you can get a bit better 60ft but a say 3000rpm stall would get you well onto the 12's and still be fine to drive on the street, just remeber every .1 off your 60ft take roughly .2 off at the finish.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2007, 01:29 AM   #5
DABOSS
BA Black Edition
DABOSS's Avatar
cheers
aldo
I know with my Gt I was able to get a 12.91 @110mph with a 2.1 60ft with bolt on's, standard running gear, and street tyres. You should be able to get the same sort of times out of your's easy , running 109mph.
"With enough money anything can be done"
"First BA to run a 12 on street Tyres and full weight back in the day, And still the quickest street BA GT in OZ"
DABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2007, 10:08 PM   #6
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
A 1.8-60' should get you a 12.5-12.6,
This is what I used to run with 109mph and a 1.8-60'..
This was in an old falcon with a 3.5 rear end,2200 stall and street tyres.
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2007, 07:25 PM   #7
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Just remember that with lower diff gears and higher stall, it has a much higher potential to get off the line quick, but the challenge increases.....not to blow the tyres up in smoke!!
Avoid at all costs ANY wheelspin.....I can see you lighting it up now! The 60ft is definitely where you'll find your 12 sec et! Good luck!
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2007, 11:48 AM   #8
Aldo
Aldo's Avatar
hahaha trublu you have no faith......neither do i.
I,was hoping to head out to willowbank tomorrow but the weather has turned sour up here, guess i'll have to wait for the new year.
I just remembered i was also doing a small burnout on my street tyres,mainly for fun, so this time i'll try and resist and go burnoutless .......maybe not on my first run
cheers boys
Xw ute
Toploader
Old 28-12-2007, 08:27 PM   #9
TruBlu351
TruBlu351's Avatar
Yeah, maybe drop the tyre pressures a bit too.
Old 30-12-2007, 12:46 PM   #10
northey
cheers boys
Good to see quick times like that on your first time out. This advice may not be sought after but I'm giving it anyway. lol.
If you're car's running well enough leave it alone and experiment with driving changes only for a couple of meetings.
Whatever you do make only ONE change at a time. If you make two or more alterations and the car responds to the changes which one did work and which one didn't? Take some of the guesswork out of it and you'll be better off than most drivers there.
There is a heap of time and speed to be made up with shifting gears at different times and, as you mentioned, start line revs.
Enjoy it; it's a great sport and is very technical (if you want it to be) no matter what level of car you run.
northey is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2007, 09:34 PM   #11
Quadcams
Quadcams's Avatar
Good advice there northey, there alot of gains with just the driver alone.
