Old 11-10-2007, 07:29 PM   #1
4dlvr
4dlvr
Default how much thrashing is bad???
i feel bad when thrashing my 04 zetec. i used to do it all the time with my i6 fairmont. but the zetec being a 4cyl i dont no if the motor/gearbox can take it.
so my question is how much thrashing can a zetec take???
i never thrash it when its cold but on private roads i reguallt take it to 6500rpm, doulble clutch, flat shift, and drop the clutch at about 5000rpm.
should i be worried??? can the car take it or should i stop??? :
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2007, 07:37 PM   #2
DOC
DOC's Avatar
LOL smack that puppy hard, dropping the clutch at 5K might not be a good thing.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2007, 08:12 PM   #3
XR8 Uterous
Just remind everyone of this thread when you go to sell the car :P
XR8 Uterous is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2007, 08:15 PM   #4
MoreHPformyXR6
MoreHPformyXR6's Avatar
Are you only your orginal clutch? If so what state is it in? :
FGX XR6 Lightning Strike Sedan
BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten
mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw.
Originally Posted by ATMO SIX
You have become the new SLOANY mate, no real quality to your current post(s).
MoreHPformyXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2007, 08:39 PM   #5
photn
AFF Post NAZI
photn's Avatar
The Zetec can take that damage. The gearbox in it is from a Ford Escort Cosworth. Built to last. The only thing i wouldnt be doing is droping the clutch. apart from that its normal wear and tear. she should be okay...
Old 11-10-2007, 08:52 PM   #6
BlackLS
yum
No dropping of clutch, no clutchless shifts and also holding it on redline of extended periods isn't a great idea either. The Focus drivetrain is less fragile compared to the Falcon drivetrain in terms of engine cooling and manual gearbox
Also why do you double clutch? From my understanding its for a slower, smoother shift.
Keep the clutch slippage/heat down and sudden drivetrain shocks and it should be all sweet.
2005 LS Focus LX
250,000kms.
Old 11-10-2007, 10:31 PM   #7
Mick K.
Mick K.'s Avatar
If I remember correctly, the LR Zetec achieves maximum power aroud 5000-5500rpm and has a flat torque curve from around 2000rpm, so it is a bit pointless to be taking it up to 6500.
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 12:49 AM   #8
4dlvr
4dlvr
it a bit of fun to double clutch in the wet, its still got the origional clutch and is in near perfect condition ill say, i let my little brother drive the car(just got his l's) and didnt stall once.
il just like to say that im never like this on the road, i actualy have have heaps of respect for other road users.
only when im up in the country on private roads
96 EF FAIRMONT
215rwkw @7psi
Old 12-10-2007, 01:39 AM   #9
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
MK
yeah, but it sounds cool.
Actually, i found down at Wakefield Park that it changed better at roughly 6000RPM, i know there's no more power there but it seemed to accelerate better in the next gear. Especially 2nd to 3rd and from 3rd to 4th. It's just my opinion but it didn't seem to 'bog down', for lack of a better term.
I made sure not to take it to far past 6k tho, it is my road car after all.
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 09:00 AM   #10
photn
AFF Post NAZI
photn's Avatar
reason it felt better was because, as you had the engine at a higher RPM, when you changed the revs didnt drop as much so basically when you changed you kept the revs in a much higher RPM band therfore keeping your power and torque essentially.
Old 12-10-2007, 09:22 AM   #11
rodderz
rodderz's Avatar
Cars will cop it just be prepared to pay for broken and worn stuff much earlier than expected, more servicing and little noises and squeaks appearing
I've gave my 1st couple of cars a hiding and it's all fun and games till you have to lay out $$ to fix things!
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 02:27 PM   #12
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
I always double clutch on the down shift, just habit now. Don't know if it's slower, certainly smoother.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded.
kiwijohn42 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 04:35 PM   #13
20focus05
I wanna XR5
20focus05's Avatar
doubling clutch on syncro box can cause extra wear on the syncro's
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 04:41 PM   #14
zetec
Zoom Zoom
zetec's Avatar
I'll take it further... double clutch on syncro boxes is not needed...
2012 Mazda3 MPS
Old 12-10-2007, 06:15 PM   #15
MattyZetec
MattyZetec's Avatar
Agreed Zetec - a double-clutch is not NEEDED on a synchro box.
However, making a SMOOTH downshift (without double-clutching) requires a fair amount of clutch slippage and takes time. Double-clutch downshifts, when performed correctly, facilitate a SMOOTH downshift in a fraction of the time.
If I'm bailing hard into a corner and need a smooth downshift to avoid excessive forward weight-shift through the engine-braking effect (and sending my back tyres sideways) then I'd surely elect to use a double clutch downshift to make the downshift quickly.
Double-clutching certainly has application when driving enthusiatically :-)
2007 LS Focus Zetec
Titanium Gray, Manual, Leather
MattyZetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 09:48 PM   #16
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
How?
Double clutching helps shift quicker & smoother, how can that wear the syncros?
Old 12-10-2007, 09:51 PM   #17
Ives
Ives's Avatar
Less cylinders doesnt mean less tough. If that theory is true then a W16 car is indestructible.
Old 12-10-2007, 10:33 PM   #18
pertuan
Focus on my Focus
Stupid question but whats double clutching? :S
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 02:29 AM   #19
4dlvr
4dlvr
i use double clutching to get the car to spin up on turns, ive never tried it to make down shifts better, if possible can some one explain???
ive tried it and it preety much felt stupid
96 EF FAIRMONT
215rwkw @7psi
Old 13-10-2007, 02:36 AM   #20
Piotr
Non-Regular Member
Just learn to heel-toe dude
Old 13-10-2007, 04:48 AM   #21
BlackLS
yum
4rdlvr, I think you aren't double clutching but "clutch kicking"
To double clutch properly into a lower gear, you need to clutch in, take out of gear, clutch out, raise revs so that the engine/input shaft of the gearbox RPM will match the RPM of the gear you want to go into, clutch in, select gear, clutch out.
Honestly I think its a waste of time, Henry has given you a syncro gearbox, use it!
If anyone wants a manual challenge, try clutchless shifting.
2005 LS Focus LX
250,000kms.
Old 15-10-2007, 07:05 PM   #22
Tj-zetec
Tj-zetec's Avatar
Has anyone successfully done this in their focus?? I can't for the life of me get it right in my LR. The accelerator pedal feels too far above the brake.
When I try it I usually end up jabbing the brake pedal.
maybe I just need bigger feet.
Old 15-10-2007, 11:04 PM   #23
melbzetec
Old enough to know better
melbzetec's Avatar
I can do it, but have the ST170 pedals. Mind you, the gap between the brake and accelerator pedal is fairly wide, and I really twist my foot sideways to do it (and about 30% of the time I miss...depends on what shoes I have on!!LOL)
Ideally you'd need different pedals that have the little extension on the bottom left of the accelerator pedal. I have often looked at these:
http://www.cardomain.com/item/SPA03783L
Nice bit of kit, but requires drilling of the pedals
Old 15-10-2007, 11:54 PM   #24
MattyZetec
MattyZetec's Avatar
Pedals in the LS are also crap for heel-toe action. Has anyone here bought the code:red pedals from european parts?? If so, are they any better?
2007 LS Focus Zetec
Old 16-10-2007, 02:35 AM   #25
4dlvr
4dlvr
BlackLS yeh i dont think i was double clutching, more like droping the clutch while driving.
how about changing gears real quickly while having your gas pedal flat to the floor??? is that a no no??
also has anyone tried a clutchles gear change??? i dont think i have the heart to do that to my car :togo:
also last question, when i give my car a bit of a thrashing the clutch pedal feels much shorter and heaps lighter. does this happen to anyone else???
i took it to ford and they told me they couldnt find or notice anything wrong with the clutch
96 EF FAIRMONT
215rwkw @7psi
Old 16-10-2007, 07:56 AM   #26
Bucknaked
Bucknaked's Avatar
Why on earth do you want to drop the clutch at 5000 unless your trying to do burnouts.
I've got an XR5, and I don't take it over 4500
Old 16-10-2007, 12:14 PM   #27
BlackLS
yum
Yes that is a no-no
I have; it takes a lot of skill and is probably the slowest shift in a standard car as your waiting for the standard heavy flywheel to slow down to the right rpm of the next gear. Keep doing what you do to your clutch and you'll have to learn how to do this very quickly.
The reason it does this is because the clutch is overheated and takes less clamping force to slip, meaning it takes less effort on the clutch pedal to cause it to slip.
Honestly I think a Focus is probably not the right type of car for you. I'm thinking more along the lines of a VN Commodore would suit you better.
2005 LS Focus LX
250,000kms.
Old 16-10-2007, 03:49 PM   #28
4dlvr
4dlvr
vn commodore??? anyone thats driven a decent condition vn will not throw jokes at them.
zetec is the car for me, plenty of balls when i need it, 600+km to a tank and its a good looker and fun. i test drove heaps of cars before i got it and i liked the zetec and the laser sr2 the best.
btw not that people care i am thinking of selling it and buying a xr5 turbo. as much as i love it im dying for the upgrade
96 EF FAIRMONT
215rwkw @7psi
Old 16-10-2007, 04:15 PM   #29
FOCUSonTHIS
FOCUSonTHIS's Avatar
Thrashing a Euroford just costs heaps of money because when things break. Cost heaps. Clutches cost up to $1000 to replace. When I replaced the clutch in my Focus parts alone cost me around $800.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 16-10-2007, 04:53 PM   #30
BlackLS
yum
I wasn't "throwing jokes" at the VN. It was moreso the type of "enthusiast" (term used loosely) that a VN attracts.
Plus if you blow a clutch or gearbox in a VN you can just buy another VN for $500 instead of forking out $1000-2000 on a Focus clutch etc.
2005 LS Focus LX
250,000kms.
