okelies.....the car i own is a 1973 mk1 4 door 1300 XL in lime glaze. info i have seen says that:
model number should be 11336. it is 11736. any explain?? and that the colour is T: Lime Glaze only put on cars 9-10/73. mine is 8/73 any explain?? and could some1 explain what partial VIN means. CK5PNG??? cheers Robbo
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
Model number is correct if you have the early type suspension ie shocks mounted to crossbar as opposed to floor as per Mk 2. Even though your car was built in 8/73 it still could be a 1972 model. I've owned 1974 built cars that were 1972 models. The "1973.5" model is the one with the revised suspension which everyone wants for motor sport. They were usually 2drs built in 1975 to run-out the old mk 1 shape. The Mk 2 was on-line by this time. I spoke long and hard to an ex-Ford Engineer, one ALLFORD day in Geelong a few years ago. I was fascinated, but my partner was bored rigid.
Lime Glaze was used from 1972 in Capris, so I'm sure you could have ordered it on an Escort at that time. |
#3 | |||
Paint Codes 1973 Escort (from 9/73 to 10/73) Colour Code Description A Polar White - note ID plate reads "3" O Yellow Glo - note ID plate reads "S" E Wild Plum - note ID plate reads "K" Z Wild Violet Metallic G Lime Glaze - note ID plate reads "T" R Copper Bronze Metallic I Jewel Green Metallic X Red Pepper A Summer Gold - note ID plate reads "Q" Q Yellow Fire J Calypso Green Metallic Y Kelly Green Metallic G Blue Teal E Pottery Beige 7 Walnut Glow Metallic 8 Cosmic Blue Metallic C Skyview Blue my car being lime glaze "T"
Model code 11736 4dr early suspension type
Model code 11336 4 dr later suspension type Paint colour codes vary quite a bit btwn 1969-75. From 1975 they changed every year, some colours were dropped, old ones allocated different codes. I can only confirm 1969 to 1972 in the Mk 1s and 1975 and 1977 in the Mk 2s from the info I have. You need to get a workshop/parts manual from 1973 to be 100% on codes. |
ok...thanx whooligan...is the 11336 better than 11736?
Ute Forum Moderator
![]() Join Date: Dec 2004
I think one of the main changes was the rear shocks are mounted in a much more upright position - ie in the same direction as they are working!
but the better one is?like what code?
Ute Forum Moderator
The later car. The third digit would be the model year indicator - ie 11736 for 1967 and 11336 for 1973.
escort relesed 68 though ???
7 refers to 1972 & 1/2 model as opposed to 3 which is 1973 and 2 which is 1972.
Best book for code disyphering escorts is Ford Escort Down Under by Cliff Chambers. If I get time, I'll scan the page and post it here. |
#11 | |||
