Hey there,
Looking into buying a soarer and don't know alot about em exept they look awsome!!! Was just wonderin what u guy's know/think. Thanks |
Impressive...
they seem to be a good cheap way to get into some moderate performance, personally i'm not a fan, just be sure to do lots of homework on imports before purchasing.
2007 WQ Fiesta XR4
Performance Blue with Stripes |
1999 Ford Fairmont Ghia
Go the V8 version if you can (3UZ-FE) I think it's rated around 220kw and is DOHC the 2JZ version is overated.
#4 | |||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Even if they are slightly over-rated I still think that they are a pretty good engine.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
The 3UZ-FE is the better pick, if you wan't a real straight six go BMW or the good old Ford Aussie Six which has a stronger bottom end and makes huge amounts of torque when turbocharged.
Seeing as your a ricer fan rev28k your obviously biased as I am towards Fords but it is obvious that a lot of vehicles in the ricer scene are overated biggest examples being Hyundai Excels, Nissan Pulsars and non-evo Lancers. Nissan put better investment into their sixes than Toyota so I know it's cliched but a Nissan RB engine is the better pick but I personally would recommend a SOHC XR6 as they are extremely underated vehicle with a bulletproof bottom end |
#6 | |||
Professional Mouse Jockey
Make sure all the electronics work. Being a high end Toyota/Lexus there is a lot of electronics in them. I was going to buy one about 5 years ago. Never happened though.
Isuzu MUX for towing horses - currently no Fords in the stable Time flies like an arrow; fruit flies like a banana. Groucho Marx
Force Fed Fords
190kw for the V8
207kw for th TT6
BA XR6 TURBO 310rwkw and always chasing more Now with 6th Gear RAPID PERFORMANCE ORSM FORD CRUISER
#8 | |||
inconceivable!
The 3UZ-FE is a beautiful engine but at the end of the day it depends on what your after. If you want power, the after market for the 2JZ is huge, I know of a few guys that run 9's and don't seem to have too much problems. If you want to cruise around then I would suggest the 3UZ-FE. |
#9 | |||
The V8 has everything you'd want in as far as specs go ( quad cam, SIX bolt mains), can rev and make good power but has been left behind on the aftermarket front. The 2jz is massively strong, an uprated turbo and an uprated fuel supply will see better than 500 hp on the dyno. Anywhere between 600 and 900 HP have been recorded more than just once on a stock bottom end with an appropriate sized single turbo. There have been 2jz powered cars into the low 10's on stock internal engines (crank/bearings/pistons/rods/head/bolts - maybe revised cam timing), so advocating the v8 to be the pick of the two is kinda misleading. Just do some research, There are heaps of forums around that deal with 2j powered vehicles, and they'd have better answers for you than I. |
i agree with Decadentia, i dont think the 2jz is underrated really especially incomparison to the v8 verision. my brother is into imports a bit and reading some of his mags and other stories that come thou him, i have good reason to believe that the stock internals will be able to put up with 500 -600hp before you will be considering strengthing the internals (for the most part but not always). i dont know that much about the v8 thou.
Current ride Bf xr6 turbo sedan, 6 SP auto, Leather/suede interior |
All this stuff is great guys thanks heaps! Looking to go the tt 6, seen a few around but i don't know how reliable they r as far as turbos go?
#12 | ||
I was going to buy one about 5 years ago. Never happened though.[/QUOTE]
Do u remember what sought of $$$ they were fetchin back then? |
Truth be known mate the models you'd be looking at would actually have the 1jz engine in them, which probably doesn't quite have the reputation that the 2j has, but is still a capable engine. They're a reliable engine and they have toyota reliability on their side, so not much goes wrong IF everything is sound and as it should be.
As I mentioned, there are forums that deal with the JZ series engines, they were in soarers and aristos, so find a forum that deals specifically with them and they'd be able to help you a bit better. The V8 model would have the 1uzfe engine in it. |
#14 | ||
inconceivable!
Normally they are fairly reliable but, find out as much as you can about the service history. A well kept and serviced one shouldn't give you much problems. If it's been a bit neglected and not serviced regularly then your better off leaving it alone.
#15 | ||
Guy at the end of my street had a lexus v8 version with twin pipes, may not have been going fast but it sounded terrific. Very throaty rumble.
#16 | |||
Japan has built some good V8's which are really overlooked in the hoo haa about their turbos if it was me I would go for something different just my opinion. |
#17 | ||
Yeh mate v8s the go if i went rice id go big **** off v8 rice
#18 | ||
Force Fed Fords
I have driven both V8 and TT version in 92 models. The TT had so much more poke, the V8 was sluggish. Relatively cheap car for what you get. Look for a TTL or similiar, but the issue is, the clocks are quite easily put back, so you don't really know what you are getting. Not many come with LSD, but a few are optioned with reverse cameras, leather etc.
2021 Focus ST-3 Mountune Enhanced |
#19 | ||
Snoopping
The 3UZ-FE is the cruiser spec, the performance versions used the 2JZ-GTE. There are a couple of Aristos with the 2JZ-GTE that are running 13s with just intercooler, exhaust and FCD. The 2J is over engineered since it was always meant for luxury/performance useage. The 3UZ is just as over engineered, can't remember if the twin turbo 3UZ Celica runs stock internals. Word of warning, while fairly cheap to buy, they can be VERY expensive to fix.
#20 | ||
The 3UZ-FE was a brilliantly designed V8 that gave the Chev and Ford V8's a good run while the 2JZ is a BMW wannabe.
