18-09-2006, 02:10 PM | #1 | ||
Oops, I slipped....
Hey Guys,
After taking the front bumper off the EF to change the trans cooler, I noticed a copper pipe running across in front of the radiator. It leads to the power steering pump, and the other end goes to the rack. I've had trouble boiling the power steering fluid before and was considering fitting a cooler, so now I might run the power steering fluid through the old trans cooler instead. My question is, do the coolers come standard fitment on E-series, or is it an aftermarket thing? I've circled it in red in the pic below. http://img.photobucket.com/albums/v4.../PS_Cooler.jpg Thanks, Aaron.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
18-09-2006, 03:05 PM | #2 | ||
Pretty sure only Sprints and GTs got them. At least in EA-ED.
18-09-2006, 05:09 PM | #3 | ||
Two > One
Darin's EL V8 has one, and im 99% sure my car has one.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
18-09-2006, 05:12 PM | #4 | ||
i have seent that most ef-el's have the same cooler as you have, some have larger ones, similar to tranny coolers.
rare as on earlier e-series. i believe that ed futuras and fairmonts didnt get them as standard.
Powered by Rollin Motorsport Turbo Barra ED 4L
18-09-2006, 05:14 PM | #5 | ||
likes falcon's
they solved cooling issue with the ef and started using synthetic fluid, or the old and time to replace looking brown stuff
www.carhubsales.com.au |
18-09-2006, 05:21 PM | #6 | ||
Last warning
6's have a much smaller one.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
18-09-2006, 05:24 PM | #7 | ||
Last warning
hxxp://opax.swin.edu.au/~glenneaux/C.../Image1003.jpg
in that pic you can see it bent up out of the way. thats the same thats on my EF GLi. i rmeember when i was over there and you were 'practicing' you had issues with the power steering boiling. i guess trans cooler is the easiest way to do it.
18-09-2006, 06:58 PM | #8 | |||
Oops, I slipped....
18-09-2006, 07:10 PM | #9 | ||
Location: Under the bonnet, trying to keep as clean as above!
this is what was on my mate's ED futura classic I6.
unsure if it was standard. car is auto and didn't have the tow pack. pete j |
18-09-2006, 09:05 PM | #10 | ||
eec tweaker
Aaron, my EF Fairmont 6 came with the same trans and PS cooler setup as yours. I off the ****y trans cooler for an ebay jobbie the other week, i never realised they were so tiny! Probably work great for the PS if you mounted it on the opposite side.
