Old 01-09-2006, 06:48 PM   #1
revcore
revcore's Avatar
Default KB Laser problems
I'm having a few probs with the Laser. She konks out sometimes when I put the brakes on. Thats the first problem. Now the second problem: When going up hills with the foot to the floor she only wants to do about 40 K's. It doesn't blow smoke and it isn't noisy (Just a slight tappet noise). I have put a new air filter in it 3 days ago.
If anyone can help me and advise me on possible causes for what could be stuffing the old girl up then I'd be mighty greatful.
Thanks fella's.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2006, 07:49 PM   #2
rag top
rag top's Avatar
Sounds like she might need a bit of a tune up. when was the last time it had one?
Old 01-09-2006, 07:52 PM   #3
VippiN
What a performer!
VippiN's Avatar
Auto or Manual mate? Up a hill in your 1.3L/1.5L carb, it's not going to go very fast. In an auto even slower. You can't expect too much mate, find a less steep route.
Get back to me on what transmission it has.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2006, 08:03 PM   #4
revcore
revcore's Avatar
It's an 1.5 auto. I can get it up to 80 K's on the hills I drive up without the car struggling very much but today it was struggling at half that. It was tuned up 2 months ago (Oil change including filter, Air filter, Fuel filter, New plugs. It has an elec dizzy so didn't need points).
My Ride...
Old 01-09-2006, 08:09 PM   #5
rag top
rag top's Avatar
When was the timing last checked?
Is it possibly a bad batch of fuel?
Old 01-09-2006, 11:53 PM   #6
rag top
rag top's Avatar
Revcore,
Did it start playing up overnight, and both the power loss and the stalling start at the same time? If it did, you could try the following (this is what my mechanic mate did did to cure the stalling and power loss in my early 80's 1.5L mazda 323):
Take the top off the air cleaner, swap plug leads for cylinder 1 & 2, then start the car. let it run for a bit and then shut it off. then swap the plug leads back. Do the same for plugs 3 & 4.
Finally, spray carby cleaner down the throat of the carby. Start again, and let it run for a bit. finally, put the top back on the air cleaner.
Old 02-09-2006, 10:23 AM   #7
revcore
revcore's Avatar
It started playing up yesterday morning as soon as I left the servo when I put $20 worth in. Before then it was going well. So I'm guessing there may have been a bit of water in with the petrol (The fuel supply tank at the servo may have been low with a bit of water seeping into it). I'm going to take it for a drive again today and see how it goes. If it's still the same then I'll do what your mechanic mate said.
Thanks for the advice.
My Ride...
Old 03-09-2006, 11:07 AM   #8
VippiN
What a performer!
VippiN's Avatar
Bad batch of fuel could be the problem. Personally i'd empty it out (should be a bolt on the bottom of the fuel tank like the sump) and refill with a Premium fuel with some additives.
