Old 29-08-2006, 08:19 PM   #1
FPV GT
I Like To Shake It
FPV GT's Avatar
Default AU Power Window Motor Removal
Hi there;
I think my drivers window motor is cactus, the switch will operate the passenger but not drivers, hence why I think its cactus.
Could someone tell me if I am on the right track, and if any problems may arise with the removal of the power window motor.
After removing trim
One. remove three motor retaining screws
Two. remove two window clip / regulator screws at the top
I havent removed the top to screws as I thought the glass may come down... (yeah coward....)
Any hints.
Regards
Paul
Regards
Paul
2016 S550 TY GT Coupe....some loud bits and some glass bits
I like My GT SHAKEN, and Blown
Happiness is a TY S550, a 1911 semi automatic, and the Lovey Lizzie by my side.
Originally Posted by Lovely Lizzie
whilst looking at man riding a pee wee 50
"That sure does nothing for his masculinity"
FPV GT is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2006, 09:55 PM   #2
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Originally Posted by FPV GT
Hi there;
After removing trim
Any hints.
Regards
Paul
Have you got power to the switch,and then power to the motor Ive had a switch play up before.Might pay to check if you havent already.
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2006, 10:16 PM   #3
FPV GT
I Like To Shake It
FPV GT's Avatar
ratio 3.99
Thanks, I checked for power and all is okay there.
Regards
Paul
Regards
Paul
Old 29-08-2006, 10:24 PM   #4
LOWAU
___________
LOWAU's Avatar
There was a little trick you can do to reset the power window, I think you have to flick the switch 31 times up and down. Try that before you remove it.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2006, 10:59 PM   #5
chief
FTF Club Moderator
chief's Avatar
FPV GT try this it worked for me.
http://fordforums.com.au/showthread.php?t=17267
The contacts on the power window switch may be dirty and there fore contact is not being made.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 03:38 PM   #6
FPV GT
I Like To Shake It
FPV GT's Avatar
Thanks Chief;
Carbon 'n' crud build up is a common fault with au switches, my XR8 had that problem.
I have swapped the working switch over, but alas no go, thats why I think the motor is shot.
Regards
Paul
Regards
Paul
