STR8 6
Im thinking about putting a K&N air filter in my EL. I have heard that the pod must be inside the box, and i have also seen a stainless steel cover that goes over your pod, are these legal??
Thanks, Cameron. |
Meh should be no one will notice.
I dont know much about it due to me being a bogan. |
Pimp Daddy Pimp Pimp
Location: Queensland Events Assistant Co-Ordinator. Fiery's Little Helper
Yes its illegal to have a open pod.
Got a Qld, Contact Us PM ULTIMATE PM FIERY (The Guru) --------------------------------------------------- AFF Merchandise Excellent Purchases With: AFF Team, Rooster, Russ |
As if a open pod isnt that with the filter showing that sucks
#5 | |||
ZX-6R & Falcon pilot
Cheap, Fast, RELIABLE. You can only have two. |
#6 | |||
Back in Blue!
Previous Ride 1: XE wagon 4.1 on LPG - RIP Previous Ride 2: VN Berlina wagon 5.0 EFI Current Ride : EF XR6 wagon (Manual!) Back in Blue baby! |
Depends on the application.
I use a K&N Flat panel filter with a Tickford snorkel in my EL for that reason, I don't want it sucking in hot air, which is less dense than cold air. But I have a pod on my MR2, as its designed to draw air from underneath the car, up through the (mid-mounted) engine bay, and out through the vents in the engine lid. So having a pod filter is fine, as there is a constant stream of cool air cycling through the engine bay. However, if you were to undertake some extra plumbing in the Falcon and put the pod down near the radiator where it would cop plenty of cool air, then it would be fine.
