#61 | |||
Russ
#62 | ||
Ahh, thank you. Much appreciated!
AUIII Falcon Forte, with SIX Appeal |
#63 | ||
Ford Fanatic
AU2 F24181 Q6 ARMREST ASSY - FRONT DR, LH, XR, WARM CHARCOAL, WITH LEATHER TRIM $56.10
AU2 F24181 Q6 ARMREST ASSY - FRONT DR, RH, XR, WARM CHARCOAL, WITH LEATHER TRIM $56.10 are these two items what i have the arrow pointing to in the attached picture or are they the handle infront of the power window buttons |
#64 | |||
Russ
#65 | ||
Does anyone know if you can buy the chrome inserts that go on the bumper and door protector strips that were on AU2 Ghia and AU3 futura/fairmont etc.
And maybe a rough price if anyone knows? Cheers, Phil |
#66 | ||
You can actually get it in the aftermarket in a range of colours.
The Silver (chrome look) finish from the AU2 XRs is still available for the door trims as per below: AU2 F20860 A MOULDING INSERT RH, SILVER, XR $48.40 AU2 F20861 A MOULDING INSERT LH, SILVER, XR $48.40 AU2 F254A58 A MOULDING INSERT RH, SILVER, XR $34.90 AU2 F254A59 A MOULDING INSERT LH, SILVER, XR $34.90 Doesn't look like any of the bright bumper ones are except the LTD rear one. Will keep searching Russ
#67 | ||
Front (these from an SVP)
ER 17D889 B MOULDING BMPR, 75TH ANNIVERSARY SVP, RH - BRIGHT, 4 DOOR SEDAN, FUTURA/GHIA about $45 ER 17D934 B MOULDING BMPR, 75TH ANNIVERSARY SVP, LH - BRIGHT, 4 DOOR SEDAN, FUTURA/GHIA ditto Rear only looks like this one available - NR 17C772 A MOULDING RR BUMPER, BRIGHT FINISH, (FAIRLANE OR LTD) about $30 Cheers Russ
#68 | |||
Ford Fanatic
thanks russell |
#69 | |||
Thanks for the help Russell Bit pricey tho :( Cheers, Phil |
#70 | ||
Posts: n/a
For Weathershields, Bonnet Guards, Rear dust deflectors and headlight guards, check out www.bodyshield.com.au
Discounts for forum members. Good Quality Airplex brand products. Give me a buzz on (07) 55648225 Nathan@bodyshield.com.au Thanks guys. You'll be glad you did. Nathan |
#71 | ||
XB in parts...
Might just do that as I wouldn't mind a weathershield for the driver's
side window...
Daily Driver 2019 Ford Escape...looking for XR6T's. |
#72 | ||
Anyone know the part number for the strip on the passenger side of the dash, which is above the glove box? Just above where the air bag comes out of...
Mine is starting to wrap :s If I could get it in carbon fibre look I think it would look good.. Is it easy to swap? Just a simple peel off and glue the new one back on? |
#73 | |||
If so here are the options: ER F04268 A6 MOULDING I/PANEL UPP, VIRTUAL CAMPHOR, (-)T-SERIES $80.10 ER F04268 B1 MOULDING I/PANEL UPP, DK GRAPHITE METALLIC, FORTE / FUTURA/S/XR $7.65 ER F04268 B10 MOULDING I/PANEL UPP, ONYX PEARL, CLASSIC' SVP, 4 DR SED, FORTE/FUTURA $21.20 TAU F04268 A MOULDING I/PANEL UPP, URBAN GEOMETRIC FINISH, 4 DR SED, T-SERIES $105.00 TAU F04268 B MOULDING I/PANEL UPP, RAINDROPS FINISH, T-SERIES $102.00 TAU3TVE F04268 B MOULDING I/PANEL UPP, RAINDROPS, T-SERIES $88.68 Cheers Russ
#74 | ||
not here much anymore
Just to further comment on what Russ has posted up:
'Virtual Camphor' is the name given to the Woodgrain in the Fairmonts/Ghias/Fairlanes. This is IIRC 2 seperate parts - the strip, and the MDC (which is the bit with the 2 screens, and is NOT included in the prices Russ has listed), and will not fit anything other than a Fairmont/Ghia/Lane/T Series dash. Similarly the Carbon Fibre one is exactly the same, just obviously with a different finish. The Forte/Futura/XR one goes above where your airbag is.
RAM 1500
#75 | ||
Uterus M.I.A.
Parts to suit AU2/3 XR8 & 6
mud Deflector guard (black plastic bit that sits under the front bar) PN: ER 8B384A $52.70 TRADE Drivers side indicator (sits in front bar) PN: ERTVE 13368A $54.60 TRADE
#76 | ||
Oh Yeah!
Hay Russ I was wondering can you buy parts of an au2 cluster seperatly its for a forte model. We need the needle and pin with it well not sure as we stuffed it up getting it out. Took it out the same as all the others but the fuel guage took the pin... not sure what to do?
Im wondering if ford can repair it themselves |
#77 | ||
I don't think so but will check.
Russ
#78 | ||
Oh Yeah!
ER 10890 B, ER 10890 A
Russ thats the part number i got from the database for A MASK INST CLUSTER, PAINTED. A is for the normal forte while B is for the police pack. I was wondering do you know the difference between the two? |
#79 | |||
As far as I know the Police mask has more graduations on the speedo.
Cheers Russ Quote:
#80 | ||
It does, and police cluster has the ability to give digital speed readout etc etc.
As far as i know the only part of the cluster you can buy seperately is the mask, which is the black bit around your dials.
RAM 1500
#81 | ||
Oh Yeah!
Yah im after the mask but I dont know how a police cluster and the forte cluster mask could be different?
#82 | ||
T-Rent-AU2
Sorry to look like another lazy person who cant read, but I want to get it right.
I need the part numbers for: 1) Entire Fairmont ghia door trims front and rear (inserts, armrests etc included) in dark charcol trim. 2) Chrome door handles 3) Leather hand brake and chrome knob 4) Chrome gear surround 5) leather console lid 6) factory fairmont ghia carpet mats
[CENTER] :evilking: AU2 Falcon Forte :evilking: - Liquid Silver P-plater |
#83 | |||
My XR cluster can give digital readouts...i thought they all did? james |
#84 | |||
Trims AU 1 XR ERT F23942 B6 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - CLOTH, XR $300 ERT F23943 B6 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - CLOTH, XR $330 AUT F24180 B6 ARMREST ASSY - FRT DOOR, RH, WARM CHARCOAL - EBONY CLOTH, XR $60 AUT F24181 B6 ARMREST ASSY - FRT DOOR, LH, WARM CHARCOAL - EBONY CLOTH, XR $58 AU1 Ghia with Leather ER F23942 F1 PANEL - TRIM FRT DOOR, RH, MED GRAPHITE - LEATHER, GHIA $400 ER F23943 F1 PANEL - TRIM FRT DOOR, LH, MED GRAPHITE - LEATHER, GHIA $405 AU F24180 C1 ARMREST ASSY - FRT DOOR, RH, MED GRAPHITE - LEATHER, GHIA $83 AU F24181 C1 ARMREST ASSY - FRT DOOR, LH, MED GRAPHITE - LEATHER, GHIA $83 AU1 T-Series - Leather TAU F23942 C6 PANEL - TRIM FRT DOOR, T-SERIES, WARM CHARCOAL - CHARCOAL, RH $660 TAU F23943 C6 PANEL - TRIM FRT DOOR, T-SERIES, WARM CHARCOAL - CHARCOAL, LH $615 AU F24180 C6 ARMREST ASSY - FRT DOOR, RH, WARM CHARCOAL - LEATHER $83 AU F24181 C6 ARMREST ASSY - FRT DOOR, LH, WARM CHARCOAL - LEATHER $83 AU1 T-Series Suede TAU F23942 A6 PANEL - TRIM FRT DOOR, T-SERIES, RH, WARM CHARCOAL - ESCAINE INSERT $363 TAU F23943 A6 PANEL - TRIM FRT DOOR, T-SERIES, LH, WARM CHARCOAL - ESCAINE INSERT $365 TAU F24180 A6 ARMREST ASSY - FRT DOOR, BLACK - ESCAINE SUEDE, RH, T-SERIES $65 TAU F24181 A6 ARMREST ASSY - FRT DOOR, BLACK ESCAINE SUEDE, LH, T-SERIES $63 AU1 T-Series Aubergine Leather TAU F23942 B6 PANEL - TRIM FRT DOOR, T-SERIES, RH, WARM CHARCOAL - AUBERGINE $595 TAU F23943 B6 PANEL - TRIM FRT DOOR, T-SERIES, LH, WARM CHARCOAL - AUBERGINE $590 TAU F24180 B ARMREST ASSY - FRT DOOR, AUBERGINE - MONTANA LEATHER, RH, T-SERIES $106 TAU F24181 B ARMREST ASSY - FRT DOOR, AUBERGINE - MONTANA LEATHER, LH, T-SERIES $106 AU2 XR AU2 F23942 D6 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - CLOTH, XR $290 AU2 F23943 D6 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - CLOTH, XR $300 AU2 F24180 H6 ARMREST ASSY - FRT DOOR, RH, W/STITCH LINE, XR, WARM CHARCOAL, CLOTH TRIM $62 AU2 F24181 H6 ARMREST ASSY - FRT DOOR, LH, W/STITCH LINE, XR, WARM CHARCOAL, CLOTH TRIM $62 AU2 XR - no stitching AU2 F23942 D66 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - CLOTH INSERT, XR $306 AU2 F23943 D66 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - CLOTH INSERT, XR $320 AU2 F24180 D66 ARMREST ASSY - FRT DOOR, RH, NO STITCH LINE, XR, WARM CHARCOAL, CLOTH TRIM $53 AU2 F24181 D66 ARMREST ASSY - FRT DOOR, LH, NO STITCH LINE, XR, WARM CHARCOAL, CLOTH TRIM $53 AU2 XR with Leather AU2 F23942 M6 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - LEATHER, XR $251 AU2 F23943 M6 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - LEATHER, XR $265 AU2 F24180 Q6 ARMREST ASSY - FRT DOOR, RH, XR, WARM CHARCOAL, LEATHER TRIM $63 AU2 F24181 Q6 ARMREST ASSY - FRT DOOR, LH, XR, WARM CHARCOAL, LEATHER TRIM $62 AU2 Leather AU2 F23942 F6 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - LEATHER $335 AU2 F23943 F6 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - LEATHER $335 AU2 F24180 Q6 ARMREST ASSY - FRT DOOR, RH, XR, WARM CHARCOAL, LEATHER TRIM $63 AU2 F24181 Q6 ARMREST ASSY - FRT DOOR, LH, XR, WARM CHARCOAL, LEATHER TRIM $62 AU2 T-Series with Wild Blue TAU2 F23942 P2 PANEL - TRIM FRONT DOOR, T-SERIES, RH, WARM CHARCOAL - WILD BLUE $536 TAU2 F23943 P2 PANEL - TRIM FRT DOOR, T-SERIES, LH, WARM CHARCOAL - WILD BLUE $565 TAU2 F24180 A2 ARMREST ASSY - FRT DOOR, RH, WILD BLUE - LEATHER, T-SERIES $125 TAU2 F24181 A2 ARMREST ASSY - FRT DOOR, LH, WILD BLUE - LEATHER, T-SERIES $125 AU2 T-Series with Impact Red TAU2 F23942 Q4 PANEL - TRIM FRONT DOOR, T-SERIES, RH, WARM CHARCOAL - IMPACT RED $565 TAU2 F23943 Q4 PANEL - TRIM FRT DOOR, T-SERIES, LH, WARM CHARCOAL - IMPACT RED $545 TAU2 F24180 A4 ARMREST ASSY - FRT DOOR, RH, IMPACT RED - LEATHER, T-SERIES $125 TAU2 F24181 A4 ARMREST ASSY - FRT DOOR, LH, IMPACT RED - LEATHER, T-SERIES $125 AU3 T-Series TAU3 F23942 M6 PANEL - TRIM FRT DOOR, T-SERIES, RH, WARM CHARCOAL $580 TAU3 F23943 M6 PANEL - TRIM FRT DOOR, T-SERIES, LH, WARM CHARCOAL $580 TAU3 F24180 M6 ARMREST ASSY - FRT DOOR, RH, T-SERIES, WARM CHARCOAL $82 TAU3 F24181 M6 ARMREST ASSY - FRT DOOR, LH, T-SERIES, WARM CHARCOAL $82 There are also a few mix and match bits - I gather that some of these panels can be mixed with the armrests already listed above. AU2 F23942 F1D PANEL - TRIM FRT DOOR, RH, DARK GRAPHITE - LEATHER, GHIA $310 AU2 F23943 F1D PANEL - TRIM FRT DOOR, LH, DARK GRAPHITE - LEATHER, GHIA $310 ER F23942 F6 PANEL - TRIM FRT DOOR, RH, WARM CHARCOAL - LEATHER $410 ER F23943 F6 PANEL - TRIM FRT DOOR, LH, WARM CHARCOAL - LEATHER $405 More interior trim bits - incomplete sets mean that the missing one is no longer available or are a mix and match: ER F23942 E1 PANEL - TRIM FRT DR, RH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$360 ER F23943 E1 PANEL - TRIM FRT DR, LH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$360 ER F27406 E1 PANEL - TRIM RR DR, RH, MEDIUM GRAPHITE - MARINA CLOTH, FAIRMONT - c$306 ER F27407 E1 PANEL - TRIM RR DR, LH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$306 ER F23942 F1 PANEL - TRIM FRT DR, RH, MED GRAPHITE - LEATHER, GHIA - c$403 ER F23943 F1 PANEL - TRIM FRT DR, LH, MED GRAPHITE - LEATHER, GHIA -c$403 ER F27406 F1 PANEL - TRIM RR DR, W/ LAMP, RH, MED GRAPHITE - LEATHER, GHIA - c$375 ER F27407 F1 PANEL - TRIM RR DR, W/LAMP, LH, MED GRAPHITE - LEATHER, GHIA - c$375 ER F23942 F6 PANEL - TRIM FRT DR, RH, WARM CHARCOAL - LEATHER - c$403 ER F23943 F6 PANEL - TRIM FRT DR, LH, WARM CHARCOAL - LEATHER - c$403 ER F23942 H1 PANEL - TRIM FRT DR, RH, MED GRAPHITE - PRADA VELOUR, GHIA - c$420 ER F23943 H1 PANEL - TRIM FRT DR, LH, MED GRAPHITE - PRADA VELOUR, GHIA - c$420 ER F27406 H1 PANEL - TRIM RR DR, RH, MED GRAPHITE - PRADA VELOUR, GHIA - c$380 ER F27407 H1 PANEL - TRIM RR DR, LH, MED GRAPHITE - PRADA VELOUR, GHIA - c$380 ER F23942 H6 PANEL - TRIM FRT DR, RH, WARM CHARCOAL - PRADA VELOUR, GHIA - c$420 ER F23943 H6 PANEL - TRIM FRT DR, LH, WARM CHARCOAL - PRADA VELOUR, GHIA - c$420 ER F27406 H6 PANEL - TRIM RR DR, RH, WARM CHARCOAL - PRADA VELOUR, GHIA - c$380 ER F27407 H6 PANEL - TRIM RR DR, LH, WARM CHARCOAL - PRADA VELOUR, GHIA - c$390 AU F23942 E1 PANEL - TRIM FRT DR, RH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$280 AU F23943 E1 PANEL - TRIM FRT DR, LH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$280 AU F27406 E1 PANEL - TRIM RR DR, RH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$255 AU F27407 E1 PANEL - TRIM RR DR, LH, MED GRAPHITE - MARINA CLOTH, FAIRMONT - c$255 AU F27406 F1 PANEL - TRIM RR DR, NO LAMP, RH,MED GRAPHITE - LEATHER, GHIA - c$350 AU F27407 F1 PANEL -TRIM RR DR, NO LAMP, LH, MED GRAPHITE - LEATHER, GHIA - c$350 AU2 F23942 E1D PANEL - TRIM FRT DR, RH, DK GRAPHITE - CLOTH, FAIRMONT - c$255 AU2 F23943 E1D PANEL - TRIM FRT DR, LH, DK GRAPHITE - CLOTH, FAIRMONT - c$308 AU2 F27406 E1D PANEL - TRIM RR DR, RH, DK GRAPHITE - CLOTH, FAIRMONT - c$215 AU2 F27407 E1D PANEL - TRIM RR DR, LH, DK GRAPHITE - CLOTH, FAIRMONT - c$220 AU2 F23942 E1D1 PANEL - TRIM FRT DR, RH, CLOTH INSERT, FAIRMONT, DK GRAPHITE - c$280 AU2 F23943 E1D1 PANEL - TRIM FRT DR, LH, CLOTH INSERT, FAIRMONT, DK GRAPHITE - c$280 AU2 F27406 E1D1 PANEL - TRIM RR DR, RH, DK GRAPHITE - CLOTH INSERT, FAIRMONT - c$245 AU2 F27407 E1D1 PANEL - TRIM RR DR, LH, DK GRAPHITE - CLOTH INSERT, FAIRMONT - c$245 AU2 F23942 F1D PANEL - TRIM FRT DR, RH, DK GRAPHITE - LEATHER, (GHIA) - c$310 AU2 F23943 F1D PANEL - TRIM FRT DR, LH, DK GRAPHITE - LEATHER, GHIA - c$310 AU2 F27406 F1D PANEL - TRIM RR DR, RH, GHIA, DK GRAPHITE - c$280 AU2 F27407 F1D PANEL - TRIM RR DR, LH, GHIA, DK GRAPHITE - $280 AU2 F23942 F6 PANEL - TRIM FRT DR, RH, WARM CHARCOAL - LEATHER - c$335 AU2 F23943 F6 PANEL - TRIM FRT DR, LH, WARM CHARCOAL - LEATHER - c$335 AU2 F23942 L6 PANEL - TRIM FRT DR, LH, FAIRMONT, WARM CHARCOAL - c$240 AU2 F23943 L6 PANEL - TRIM FRT DR, LH, FAIRMONT, WARM CHARCOAL - c$240 AU3 F23943 E1D PANEL TRIM FRT DR, LH, MONTE CARLO INSERT, FAIRMONT, DK GRAPHITE - c$313 AU3 F27406 E1D PANEL TRIM RR DR, RH, MONTE CARLO INSERT, FAIRMONT, DK GRAPHITE - c$280 AU3 F27407 E1D PANEL TRIM RR DR, LH, MONTE CARLO INSERT, FAIRMONT, DK GRAPHITE - c$280 AU Leather Handbrake / Boot ER 2760 B6 about $200 plus the boot. ER 2404 A1 BOOT - PARKING BRAKE LEVER, FAIRLANE/GHIA/LTD, MEDIUM GRAPHITE AU2 2404 A1D BOOT - PARKING BRAKE LEVER, GHIA/FAIRLANE, DARK GRAPHITE ER 2404 A6 BOOT - PARKING BRAKE LEVER, (4 DOOR SEDAN FAIRMONT/GHIA WARM CHARCOAL OR FAIRLANE WARM CHARCOAL) all about $40 Chrome door handles Part No. ER F 22600 B - R/H side & ER F 22601 B - L/H side ($25 each) Chrome look gear surround: NU 7A306 A HOUSING, CHROME HOUSING INNER, FAIRLANE/GHIA/LTD about $18 Auto Trans Shift Knobs(button not available seperately) AU 7E261 A1D HANDLE TRANS CONTROL, DK GRAPHITE - PVC, FORTE/FUTURA/FAIRMONT $21.60 AU 7E261 A6 HANDLE TRANS CONTROL, WARM CHARCOAL - PVC, 'COLEMAN MILNE' SVP $19.20 AU 7E261 B6 HANDLE TRANS CONTROL, WARM CHARCOAL - LEATHER, CHROME BUTTON, BLACK SEAT TRIM, T-SERIES $190.00 TAU2TVE 7E261 A4 HANDLE TRANS CONTROL, IMPACT RED SEAT TRIM, T-SERIES $275.00 TAU2TVE 7E261 A2 HANDLE TRANS CONTROL, WILD BLUE SEAT TRIM, T-SERIES $275.00 AU 7E261 B1D HANDLE TRANS CONTROL, DK GRAPHITE - LEATHER, CHROME BUTTON $190.00 AU 7E261 B6 HANDLE TRANS CONTROL, WARM CHARCOAL - LEATHER, CHROME BUTTON, T-SERIES $190.00 DU 7E261 A1 HANDLE TRANS CONTROL, MED GRAPHITE - LEATHER, CHROME BUTTON, LTD $184.00 Carpet Mats AU2 F13002 B1 CARPET MAT SET, DARK GRAPHITE - GHIA LOGO, GHIA $151.00 AU2 F13002 B6 CARPET MAT SET, WARM CHARCOAL - GHIA LOGO, GHIA $151.00 ER F13002 B1 CARPET MAT SET, MEDIUM GRAPHITE - GHIA LOGO, GHIA $134.00 Cheers Russ
#85 | ||
FALCON HELL!!!
Hey can someone give me some instructions on how to remove the instrument cluster from my AUII Falcon XL ute? I want to replace a couple of the bulbs but i just cant see how the bloody thing comes out!!
Do i have to pull out the whole dash to do this??? ![]() |
#86 | ||
Adapt or perish...
ERT F60004 A SEAT FRONT, RH, XR $564.00
ERT F60005 A SEAT FRONT, LH, XR $575.00 Are those the full AU XR seat, or not Russ?
Carless
#87 | |||
SEAT-SERVICE ASSY RH LESS COVERS This means you need to add the covers (that is to say the actual trim material) to make a complete seat. Indeed if I read it right you also need to add the headrest, adjusting wheel and the base! E.g: AU2 F610A62 Q6 COVER ASSY - HEADREST PAD, WRM CHARCOAL - KONSTRUCT CLOTH, FRONT, XR $60.00 AU2 F62900 T6 COVER FRONT CUSHION, RH, WRM CHARCOAL - KONSTRUCT CLOTH, XR $151.11 AU2 F64416 T6 COVER ASSY - SEAT BACK, WRM CHARCOAL - KONSTRUCT CLOTH, XR $137.51 Cheers Russ
#88 | |||
Ute Forum Moderator
#89 | |||
Once the screws are removed the cluster is only retained by a tight fit. Care must be taken to remove the cluster evenly (square to the instrument panel) to avoid damage to the instrument panel vinyl. For installation press the cluster fully home into the instrument panel and secure using the two phillips head screws. Fit new screw caps. Cheers Russ
#90 | |||
Silhouette AU1 TS50.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
