Old 04-12-2024, 07:14 PM   #1
Default NSW Rego and LPG Tank Dates
Bit of a curly question here, looking at a petrol + gas car for sale.
2013 dated LPG installation (Prinz system), vehicle rego expired August 2024. The owner is genuinely not car savvy and purchased from a family member. So he’s not sure if the tank was re-certified in 2023.
As the last rego period was from 2023-2024, is it possible to say with certainty, that the tank was re-stamped? Or are there ways it could have been passed with an out-of-date tank as a dual fuel car?
Old 04-12-2024, 07:38 PM   #2
ute83
Default Re: NSW Rego and LPG Tank Dates
I would have thought nsw's annual check would have picked something like that up.
ute83 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2024, 08:59 PM   #3
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
If its similar to WA and if your tank has 6 months left on it at inspection, they will not, or should I say they should not pass it without a valid certification of the tank, as it will expire in the period its licenced for.
When I re-licenced my RTV, it had over 9 months left on the tanks before the 10 years was up, the pit inspector told me he was not allowed to pass it as he had to put down the date of certification of the tank and it needed a minimum of 12 months left.
Hopefully for you its the same and they had to have it certified, if so there should be a small aluminium tag with a date on it near the gas certification tag or on the tank itself.
When my tanks were re tested, the test guy gave me a aluminium tag with his certification number and the test date, he told me it had to be riveted close to the gas fitters id tag and the paperwork kept with the vehicle.
If the tank is out of date you cant licence unless the whole system is removed
Old 04-12-2024, 09:19 PM   #4
I’m hoping it’s something like that, applying. Car needs a blue slip as it stands, but the issues are otherwise trivial and to re-stamp the tank would be a big extra bite of coin.
Old 31-12-2024, 08:13 PM   #5
Hmm… Looks like it slipped through the cracks last registration renewal.
Old 31-12-2024, 08:42 PM   #6
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Hmm, its not what you know then
Old 31-12-2024, 09:13 PM   #7
It would seem so!
This is going to be a learning curve.
Old 31-12-2024, 09:19 PM   #8
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
It would seem so!
My POS Jeep GC has LPG installed, and when I bought it the tank had expired. It cost about $800 to have the tank certified, but I only have one servo within 10km that sells LPG, so rarely use it.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is online now   Reply With Quote Multi-Quote with this Post
Old 31-12-2024, 09:36 PM   #9
Apparently there is a mobile tester in our area; it’s a trade only service. Hopefully I can tango with him to avoid a complete uninstall/reinstall (just removing tank) as otherwise the system seems to be working nicely. It’s a Prins SVI Series 2 that’s quite neatly installed. Glad I didn’t fill the tank while it was on the trailer!
Old 31-12-2024, 10:39 PM   #10
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
I just pulled the tank on mine and took it to the guy, from memory it was $165 for him to test and certify the tank, there is no need of proof that it was professionally removed and replaced, inspector only needed to see that it was in date and it was professionally tested.
Old 01-01-2025, 09:02 PM   #11
I’m starting to form the impression that re-stamping is a “standalone” process relying on the integrity of accredited parties, and spot audits. Not unlike AC servicing; no online logging that’s tied by a VIN or chassis number - or even a pressure vessel’s unique ID.
Old 02-01-2025, 01:36 AM   #12
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
The testers down here put on their own registered stickers. I had one recertified once, and couldn't find it after looking everywhere for ages. Had to ring them up and ask did they forget/where did they put it.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2025, 03:08 PM   #13
Crazy Dazz
Recertification of Pressure Vessels is a serious business.
  • It needs to be removed from the car
  • Completely disassembled
  • Paint Stripped
  • Visually inspected inside and out
  • Scanned with ECT
  • Repainted
  • Reassembled with a new cut-off valve and seal
  • Then Reinstalled
You will save a lot of money if you (illegally) do the removal and installation yourself.
I found the best places were those that do SCUBA tanks. They WANTED the tank uninstalled, and therefore charged a reasonable fee for the work itself.
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 02-01-2025, 05:37 PM   #14
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
  • Paint Stripped
  • Scanned with ECT
  • Repainted
  • Then Reinstalled
Pretty sure the list you have there is for a different sort of certification
LPG is around 100-200 psi
Scuba tank can be as high as 3500 psi
I had mine done through (insert suburb here) auto gas, he just pressure tested it @ 300 psi for xx amount of time, then inspected for damage /rust, there was no complete disassemble I had it back within 2 hours, no paint stripping, no repaint, he fitted a new valve or part of, he did not care who pulled it or replaced it, he was the one who told me that I did not have to show who removed or replaced the tank as the certification is all Licencing want to see, even the licencing inspector did not care as they do a gas leak check when inspecting.
He told me the only thing he has to make sure of is that the tank has no damage, no rust pitting, check welds, and that it tests fine.
Old 02-01-2025, 06:51 PM   #15
Itsme
Itsme's Avatar
Agree, also when tanks are tested a new pressure relief valve is usually installed for compliance
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 03-01-2025, 03:21 PM   #16
Dr Terry
It didn't slip thru any "crack'. The tank was stamped 9/13 & the rego was due 8/13. The tank was was compliant at the time of rego inspection.
If the tank was "in date" at the time of inspection, that's all that matters. It will not pass in 2014 however.
I do LPG rego inspections, that's the official rule.
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2025, 03:27 PM   #17
I find it odd that the last period of registration, concluding August 2024, would have taken in eleven months when the tank was out of date.
Anyway - I’ll be getting it restamped. Cleaning up the motor now, tank will come after that.
Old 03-01-2025, 04:10 PM   #18
Fatbob103
Dr Terry
100% correct. It was legal at the time. Same as you cant knock a car back for rego if the tyres will be stuffed in a months time if they are legal at the time of inspection.
Fatbob103 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2025, 07:45 PM   #19
Sorted, good for ten more years at a price to make me happy.
