Old 31-01-2025, 05:49 PM   #1
Default LPG Tank Hose: Dumb Question
This is not permanently at tank pressure, is it?
I mean, if the hose is ripped in an accident, the tank contents cannot escape via the connected hose used to fill it? I’m assuming it has a check valve at the tank end fitting.
Just checking before I accidentally blow a suburb off the map this weekend.
Old 31-01-2025, 06:16 PM   #2
351buzz
351buzz's Avatar
Default Re: LPG Tank Hose: Dumb Question
Correct. Tank has a fill valve inside it. That's the valve that shuts off when the tank is full via a float. It is a check valve.
The fill point also has a check valve that will hold pressure in the line. It can be bled off by pushing the centre bit in with a screwdriver to release the pipe pressure.
Where gloves when you do this as it will freeze burn your pinkys
351buzz is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2025, 06:29 PM   #3
Thank you. I was uncomfortable just “assuming”, considering the tank I need to remove is still holding about 15-20 litres of gas.
Old 01-02-2025, 08:35 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Turn tap off, crack pipes slowly and no drama.
Dont Smoke...
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2025, 08:09 AM   #5
roKWiz
Cabover nut
roKWiz's Avatar
He blew up Five Dock and most of Drummoyne. Ek, Ek, Ek, Ek.
Old 02-02-2025, 08:00 PM   #6
Actually, it was a successful release of line pressure with the hints from here. Tank now strapped into my ute for dropping at West End LPG tomorrow.
Old 02-02-2025, 10:09 PM   #7
Interceptor
HSV - I just ate one!
Interceptor's Avatar
It'll only blow up once......
Old 02-02-2025, 10:21 PM   #8
Yes, true. I took a photo of it before removal, just for reference when reassembling.
