Old 28-12-2024, 11:12 AM   #1
malbaby
Default Fuse and Relay Box.
Looking for recommendations on a supplier of an aftermarket quality combined fuse and relay box.
malbaby is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2024, 03:16 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Fuse and Relay Box.
The Cooper Bussman job is quite nice,
If its just a single circuit with a relay, these are quite nice:
https://www.swe-check.com.au/product...r-relay-module
If you've got a bunch of circuits, then this is pretty good:
https://www.swe-check.com.au/product...elays-dual-bus
The only thing is they use ISO280 relays:
https://www.swe-check.com.au/product...t-12v-or-24vdc
Or JAS Oceania has this, which is basically a moulded box you can put a bunch of fuses and relays into yourself:
Also this one which has a little control panel:
Or if you want to go a bit fancier, Blink Marine Keybox is a pretty decent all in one unit:
https://macquarrie.com.au/collection...b3-12v-multi-a
Gives you a bunch of 10A relay outputs that you can also program with free sofrware, more information available below:
https://shop.blinkmarine.com/product/kb312v-10a/
You can control the circuits with a basic switch panel:
https://macquarrie.com.au/collection...ts/pkp-2600-si
Or REDARC also does a nice unit which can be controlled with basic switch inputs:
https://www.redarcelectronics.com/au/tvms-rogue?
Few options around, depending on how basic or fancy you want to go.
Old 29-12-2024, 08:47 AM   #3
malbaby
Thanks for that, very interesting.
