Hi
I have an XP with a leaking 3speed gearbox and finding it hard to get it in gear. Thinking of putting an XR 3 speed synchro in. Does anyone know what has to be modified for it to work? Is it worthwhile? Thanks Heaps Darryl |
It’s the “large back” type block, like an XR?
I’m not really sure.
It’s an original 170 pursuit. It has an original 3 speed non synchro gearbox. 4 bolt holes on the top of the gearbox. Someone told me that it’s best to put a later model gearbox out of an XR falcon. It’s a much stronger box with synchro in first gear. Just wondering what modifications I need to make it work for me? Cheers Darryl |
That might be the small bellhousing type block unless it’s a very late XP, if so you’ll not find it straightforward to put the later box in. Having the selector shafts and their bushings rehabilitated could be an easier choice.
I got caught out once with the difference size bell housing on an XM ute, very frustrating.
Do some measurements to check before proceeding. |
Thanks guys!!
I will have to look into it more. |
Oh boy !
So much is involved in doing such ! It's just not a direct swap over ! The XR had a non syn 1st box standard and an option of a Syn box as well. The tail of the box is shorter for the X member of XP and XR on are longer tail ! The XR on 6 cyl has a wide rear housing to the engine block and the XK-L-M-P are a narrow rear housing to the block. and that's just the start of it all ! A mate had had a XP Hard Top from 1980 on and he put a 221 in it and 4sp box. That was the easy way out back then ! for cost as well ! |
Hi Mick
Thanks, Mick, It it really does sound like a lot of work After Much consideration I have decided to go down the original box. Don’t want to go down that conversion rabbit hole, sounds like fraught with danger. Going to get a secondhand box and then possibly get this one done up. Thanks, Darryl |
Common problem is a worn shifter fork. They just don't push the locking collar in far enough and under load it spits back out. A new fork will push it all the way in.
That’s interesting to learn. I’d assumed it was a problem with where the selector shafts entered the main housing, wearing shaft and bore.
Can the fork tips be built up with bronze (eg MIG bronze wire) or brazing? |
