Hello.
I have a 92 ford laser hatchback and it wont start, these are the symptoms: when the key is turned, the engine continuously turns over but wont start. all fuses are OK and the car has fuel. What should i do to diagnose or fix this problem. Thankyou. |
Over Thinker
if you get no spark
take one spark plug lead off and hold it close to the engine while someone turns the engine over spray all the electrical with wd 40 check coilwire - spark plug wires- coil or distributor module may have failed
My car goes Brumm Brumm |
