Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
10-05-2023, 05:13 PM | #1411 | |||
10-05-2023, 06:37 PM | #1412 | ||
Ford one is green. Not sure if it's a different material than your average o-ring, but for the sake of $5 why would you bother trying something else.
If the original lasted 10 years that means you shouldn't have to worry about it for another 10.
3 users like this post: |
10-05-2023, 11:06 PM | #1413 | ||
AKA "the other bloke"
Hi all.. just hunting a fg fpv lower grille surround? Hopefully someone can point me in the right direction. Thanks
Her's: 2000 AU II Fairmont Ghia 75th anniversary VCT meteorite & 2014 yaris - white His Toy: 2012 fg II GT-E, emperor red His: VS Ute 5 Litre 5 speed (povo pack) His: 2012 FG II GS, Vanish His: 2003 BA GT-P, Lightening Strike Jnr: 2002 AU III Falcon XR6 ST, 5 speed Blueprint & 1978 XC Fairmont Neptune Blue Previous: 1976 HX 50th Anniversary Kingswood 2014 FGX G6E Turbo 1980 XD Falcon GL 2003 BA Falcon XR6 1991 EB Falcon S 1989 EA Fairmont 1982 XE Fairmont 1968 XT Falcon |
10-05-2023, 11:13 PM | #1414 | ||
Need to be more specific, there are 4 different lower grille surrounds on FPV specific front bars, one for GT/Pursuit, one for GTE/F6E, one for GTP/Super Pursuit or F6? Which one you chasing?
11-05-2023, 05:50 AM | #1415 | ||
Tbh im looking at either a GTE one or a GT one...
11-05-2023, 08:56 AM | #1416 | ||
GT one is obsolete which was a black finish, GTE is a chrome finish and can get, but they are (hope your sitting down) $1400. Just to confirm, we are talking about part 17D749A in pic below.
FG FPV Front Bumper.jpg |
11-05-2023, 10:58 AM | #1417 | ||
i was thankfully.... but expected as much....
im assuming that part 17D749B relates to the F6 ? if so.. im assuming obsolete also? But thanks for the confirmation GT Legend..
11-05-2023, 10:59 AM | #1418 | ||
btw.. 8422 ? available for a GTE also?
11-05-2023, 05:36 PM | #1419 | ||
11-05-2023, 07:36 PM | #1421 | ||
Can you help this new member with his XC Distributor rotor search please https://fordforums.com.au/vbportal/f...php?t=11497931
regards Blue |
12-05-2023, 07:03 PM | #1422 | ||
Gt legend, 1 last question if I may, for 17D749A does that need another part to attach behind it ? If I read it right , that one is 2 parts, the frame and grille, but the top grille is 3 seperate parts?
12-05-2023, 07:14 PM | #1423 | |||
The upper grill is the same, the third part you see 17C881 is an energy absorbing foam pad. Does that answer your question? |
13-05-2023, 04:02 PM | #1424 | ||
absolutley GT Legend.. just means it's 1 less thing ill be hunting for ! Can't thank you enough for your imput.
13-05-2023, 09:58 PM | #1425 | ||
GT
I have a power steering rack on my AU2 6 cylinder that might replacement. Can any other model apart from AU2 fit or needs to be only AU2? Thanks |
14-05-2023, 11:14 AM | #1426 | |||
6 Cyl: Forte, Futura, XR, S & Fairmont Sedans AU/AU2/AU3. 8 Cyl Forte, Futura, XR & Fairmont Sedans, Forte/Fairmont Wagon. AU/AU2/AU3. 6 Cyl Ghia AU AU2 AU3 8 Cyl Ghia Tickford Fairlane & T Series AU AU2 AU3 6 Cyl Fairlane/LTD AU AU2 AU3 8 cyl Fairlane/LTD AU AU2 AU3 So based on this, unless yours is a Ghia or Fairlane/LTD, you would need to find one out of any AU/AU2/AU3 that us a Forte/Futura/XR/S or Fairmont. |
14-05-2023, 12:38 PM | #1427 | ||
Hi GT, I am wanting to do the FGX black headliner conversion to my FG Mk2 XR6T ute. Just wondering on the availability of parts, part numbers and prices when you have a chance. Thank you
14-05-2023, 12:56 PM | #1428 | |||
Here is a list of all the parts required and their part numbers. Most are no longer available. I will need to go through and update whats still available and their pricing, but most are long gone now as another member not long finished doing the same thing and is still missing items. I think easiest option would be to find a wrecked FGX and get all the trims from it. RH A Pillar trim: AR2ZF03512CBSH LH A Pillar trim: AR2ZF03513CBSH RH B Pillar trim: 8R2ZF24396ACSH LH B Pillar trim: 8R2ZF24397ACSH B Pillar Screw Cap: 8R2ZF24452BBSH (you need 2). B Pillar Seat Belt Bolt Cover: 8R2ZF610C29AASH (you need 2). RH C Pillar Trim: AR2ZF31002ACSH LH C Pillar Trim: AR2ZF31003ACSH RH Sunvisor: 8R2ZF04100ABSH LH Sunvisor: 8R2ZF0410ABSH Sunvisor Retaining Clips: 8R2ZF041K16AASH (you need 2). Roof Lamp Bezel: 8R2Z13K767CASH Rear Side Lamp Bezel: WR2Z13A701AFSH Rear Roof Lining Clips: W713485SSSH (you need 2) RH Grab Handle: 8R2ZF31406ABSH LH Grab Handle: 8R2ZF31406BBSH (you need 2). |
14-05-2023, 07:12 PM | #1429 | ||
Hi GT,
Have a 2008 FG GT-E. Looking for wiper arm caps, and also the y piece for the washers that clips into the passenger side firewall. It has an internal non-return valve. Thanks
Our FORD Stable 2008 FG GT-E - Lightning Strike 2007 BFII Fairmont Ghia - Seduce 2007 BFII Falcon ES - Ego Last edited by GXA; 14-05-2023 at 07:18 PM. |
14-05-2023, 10:17 PM | #1430 | |||
Washer Y piece is actually part of the LH wiper cowl panel and you have to buy that to get the Y piece. $85 plus postage. |
14-05-2023, 11:09 PM | #1431 | |||
Our FORD Stable 2008 FG GT-E - Lightning Strike 2007 BFII Fairmont Ghia - Seduce 2007 BFII Falcon ES - Ego |
15-05-2023, 03:32 PM | #1432 | ||
If this might help out anyone, I had issues with my Territory's non-return valve perhaps 10 years ago and fitted an ~$3 aquarium air pump non-return valve as a "temporary" solution. It is still working perfectly to the day (unless I have now jinxed it!)
'19 Wildtrak PX3 3.2 6spd, White '09 SY1 Terri TS AWD - still going strong, now wifey's |
15-05-2023, 07:05 PM | #1433 | |||
Cheers mate, I figured most would be obsolete my now. Being a Ute, I need a few less parts. I see you can still get sunvisors online at Bayford, hence i had a little bit of hope. Clips wise I'm not too fused, I'd just paint the cream ones. I agree with finding a wreck but there were not many FGX XR UTEs made in the first place and people want more $$$ than new parts. If I could the get info on the smaller list below when you have a chance. It would be much appreciated and i will reassess my options. Thank You - Both A Pillars ( G6ET fabric ones or just standard XR) - Ute B Pillar trims and screw caps - Ute Small interior light bezel ( nea rear window) - Ute Seat belt screw caps - Ute headliner - Standard Map lights between sunvisors ( i highly doubt a sunglasses holder one is still available) - 1x LH grab handle. |
15-05-2023, 07:52 PM | #1434 | |||
16-05-2023, 09:19 AM | #1435 | ||
Hi GTLegend, I'm after the three FPV badges for a B series Tornado Ute. Specifically the tailgate FPV badge (Not the F6 Tornado badge), and the two FPV badges that sit in the left and right skirts in the recessed area near the front wheels. They are a two piece badge, one part is the FPV logo, the other is the text FPV.
Cheers.
The Current Fleet: 2018 Kia Sportage GTLine 2014 FG-X G6E T 2012 FG-II GTP #288 2002 AU-III XR8 Previous rides (1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel) |
16-05-2023, 05:41 PM | #1436 | |||
Tailgate and side FPV Badges in this case are all the same. Part number BAT16237A, obsolete but there is one on eBay. https://www.ebay.com.au/itm/25576862...Bk9SR66irbSEYg Cheers, GT |
18-05-2023, 10:19 PM | #1437 | ||
Hey legend
2007 territory turbo oxygen sensor price please if still available. Does it have 2 sensors like the v8s or 1? Thanks |
18-05-2023, 10:37 PM | #1438 | ||
19-05-2023, 05:17 PM | #1439 | ||
sorry GT Ledgend.. last one .. i promise ! 8169 to suit a GTE?
19-05-2023, 05:51 PM | #1440 | ||
