I think these are transmission codes
Check for a loose earth on the LH chassis rail just under the air cleaner. If you can rotate the eyelet, then its a possibility its a bad earth and can cause the two codes you are referring to.
Could also be attributed to EGR and MAP sensor issues. |
I will start by pulling out the egg valve assembly. Thanks for your help.
Blanked off EGR and took it for a 50km run. No codes. New EGR with cooler $724 from Ford!
