Old 23-03-2019, 10:10 PM   #1
Tonz
Default drilling oversize hole in plastic
Never liked the position of front parking sensors so after kangaroo encounter and new bumper on the FG I thought Id position them in new place so drilled a hole in each fog light shroud and each side of the lower grill.... all good for 19mm then found 2 of the sensors were damaged so Ebayed new ones.....
faaaarrrt ordered wrong size and 22mm arrived.
So how can I cleanly redrill the 19mm holes to 22mm or am I better with a drill bit in the 19mm hole and just ground it out.
Old 23-03-2019, 10:26 PM   #2
Sprint XR8
Sprint XR8's Avatar
Default Re: drilling oversize hole in plastic
A step drill bit will be the easiest way.
https://www.ebay.com.au/itm/Hex-Tita...QAAOSwjvJZSkaa
Sprint XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2019, 10:43 PM   #3
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
Yep , step drills are perfect for that
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2019, 09:07 AM   #4
Tonz
age is catching up with me, I was doing a shed cleanup yesterday morning and found one of those, no idea where it came from or what/if I used it but thought nah dont throw it away I may need it someday.
Thanks peeps
Old 29-03-2019, 10:30 PM   #5
Interceptor
HSV - I just ate one!
Interceptor's Avatar
it should also be pointed out that the sensors are programmed to work in their original positions, and may give false readings if they are mounted anywhere else
