I've seen this a couple of times now and it occurs when it's dark.
It's a message to the effect that the ACS sensor is blocked and the windscreen needs cleaning. But that isn't the case because the windscreen is spotless over the sensor array. Last night it occurred as I approached a Tee junction at low speed and had the headlights on high beam which gave quite high reflection back from the diagonal striped "hazard" indication sign on the opposite side of the junction. So, I'm wondering if the sensor got overloaded by the "back-splash" of light and this caused the message as I was below the activation speed for the ACS system. Cleared the message and it did not re-activate so I'll keep monitoring the situation and ask the dealer if it gets to be frequent. Has anyone else noticed a similar warning in similar circumstances? Cheers
AlanD ![]() Our Drive: Mondeo MD TDCi Titanium Wagon Ruby Red |
Yeah. I often get this on cold, moist mornings.
Usually happens in similar lighting circumstances that you have outlined. It is not something that I have been concerned about. |
#3 | |||
Challenge Accepted!
Undecided replacement... [SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD] |
