That's a weird recall as grass gets caught up in all utes on the farm.
And the BT-50 has exactly the same recall. If you drive in grass check the build up.
I did the Canning Stock Route and we were always checking for the build up of grass. |
2 users like this post: |
Apparently the Ranger and BT-50 are more susceptible to having grass caught up round the DPF. Must be a positioning thing.
Ford screwed the Falcon
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
RS The Faster Fords
![]() Join Date: Feb 2014
The old couriers had a skid plate on the muffler that used to collect all manner of debris, the one I was driving started smouldering on a few occasions.
I can only hope this happens to my current work ranger, it'd be nice to stand back and watch it burn.
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
3 users like this post: |
Landcruiser 200
There might be a bit more to it than just grass build up ???
http://www.cairnspost.com.au/news/cr...42de272a5f89bb |
#8 | |||
![]() Join Date: Jan 2005
#9 | |||
BLUE OVAL INC.
'Ford Australia will contact owners of all affected vehicles but, in the meantime, has advised owners to refer to the warnings in the Owner Manual, paying special attention to information relating to starting and stopping the engine, fuel and refuelling.' Where is the filler position in relation to the DPF and exhaust on Rangers, same side or not? Last edited by BENT_8; 20-12-2017 at 06:34 PM. |
For once the dealership guys will be right when they say "They all do that"
6 users like this post: |
#13 | ||
Any ideas how they going to fix this? I'd have thought this is common to all modern vehicles (cats, DPFs, etc) and largely a matter of common sense .. which can't be "fixed".
#14 | ||
Landcruiser 200
Ok. I think we all know that any vehicle can catch fire when driving through long grass because of the extreme heat build up around the catalytic converter and/or turbo areas.
What makes the Ranger unique here ?? |
#15 | |||
Experienced Member
#16 | ||
Bit more of an explanation there - I love my 4wding and am a subscriber to Mr 4x4.......
https://mr4x4.com.au/ford-ranger-bt-...ble-fire-risk/ |
#17 | ||
I think there will be some sort of cover or plate to stop the build up of grass in that area.
#18 | |||
BLUE OVAL INC.
From the article.. How to fix the problem? In serious conditions, you’d be wanting to do hourly checks under your vehicle to see how much grass is building up in problem areas. You can keep an eye on it, and get a good idea of where and how often you should be checking things out. Keep a long tent peg and some sturdy gloves handy, and use these to fish out the collected debris. Beyond that, a true ‘solution’ to the problem might be impossible, beyond buying a Unimog. You could go out and buy an older 4WD without a DPF, or one that has exhaust routed in a way that helps keep it clear of collected grass. Your other option is to fashion some kind of plates or skids under your vehicle, which will push the grass away rather than collect it up. But undoubtedly, the best thing you can do is be aware of the problem, and keep an eye on it, no matter what vehicle. And of course, when you’re travelling remotely, you need to subscribe fully to the idea of self-sufficiency. That means carrying a fire extinguisher, and having it somewhere easy and fast to access if the faeces hit the fan. And, know how to use it. |
#19 | ||
Performance moderator
![]() Join Date: Feb 2005
shield & wrap it ???
