Old 11-11-2017, 10:38 PM   #1
blue sleeper
blue sleeper's Avatar
Default Holden V8 5.0 Litre 3 valve
I seem to recall the workers at Elizabeth, creating a 3v version of the Holden 5 litre as a prototype before the Gen 3 came along. I read it in a Wheels/Motor mag in the late 90's. Does that ring a bell with anyone?
Had: ED Fairmont AU engine 5 speed exhaust extractors, 17" mags, miss the old girl....
Have: 1JZ Soarer dump pipe, exhaust, coilovers , 17" mags
blue sleeper is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2017, 10:59 PM   #2
4vxc
Default Re: Holden V8 5.0 Litre 3 valve
Street Machine mag did a small article about that recently.
Nothing came of it
4vxc is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 01:11 AM   #3
MethodX
MethodX's Avatar
GM America were supposed to be experimenting with 3 valve heads for the LS, using a split rocker.
Guess nothing came of that either.
MethodX is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 10:30 AM   #4
Dr Terry
They prototyped quite a few different head designs over the decades, including OHC & K-Jetronic injection.
The engine design facility that worked on these was nick-named the "skunk works", but was actually at Fisherman's Bend (Port Melbourne) not Elizabeth. All Holden engines were built in the same place since 1948 & then transported to all the body plants. The only one left being Elizabeth.
Dr Terry
Dr Terry is online now   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 11:07 AM   #5
boss351290
They canned the 3 valve head because it only made a few kilowatts more than the 2v head
boss351290 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 12:27 PM   #6
roddy1960
roddy1960's Avatar
G'day , Interesting to see this was considered . GM have done a lot with the LS range so I suppose they decided not to complicate it anymore when it worked pretty well anyway ..If it ain't broke , don't fix it you might say .
A mate of mine has a Falcon RTV with the 260 KW 3 valve 5.4 litre V8 and it's had lot's of trouble with cam phaser issues and required a fair bit of moola to sort out on the 3V . I know the Holden stuff is different beast but less complicated for only marginal loss of power makes good sense . I think the 4V quad cam 5.4 L made 290 KW without the VCT issues didn't it for Ford until it was replaced with the mighty 5.0 litre Coyote/Miami . What a beaut donk that is. So is the range of 6.2 litre Chevy mills for sure . Cheers Rod.
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 01:18 PM   #7
Nu66et
5.4 3V was 220-230kw factory. 5.4 4V couldn't physically fit VCT
Nu66et is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2017, 01:21 PM   #8
Interesting. Chevy experimented with 3 valve chambers for the Gen I small block back in the 60s. Mickey Thompson actually developed a 3 valve small block Chevy for Indy some time mid-late 60s back when all kind of combinations were competing together.. I don't think much happened with it.
