#31 | ||
I think that the buying public are having their expectations lowered in regard to reliability.Vehicle manufacturers have every one convinced that faults are to be expected in mass production.But realistically when spending $30,000 to well over $100,000 we should expect to get something that will be completely trouble free for at least 250,000 kms.
#32 | ||
Posts: n/a
Are you saying that all the guy (from trublu's video) had to do was turn off his car and the engine would have suffocated itself?
#33 | ||
Very good point, considering you see posts here and elsewhere alluding to the fact that after 20,000 km they haven't had a problem ! Really... I would be a little bit ****ed if spent 50G on a vehicle and it developed problems within a 2 year time frame.
Isn't the whole idea of buying new to avoid the issues of buying someone else's dramas. Seems you can just go straight to the source these days and cut out the middleman. We used to buy 11 Commodores in one hit in the 80's thru to late 90's for rep work, kept for 3 years max covering all of Qld and as far south as Taree. In that time nothing failed/died to stop someone getting home. It would have probably been the same outcome for the equivalent Falcons of the era if that was the companies choice. You would think that out of 11 cars you would get a bit of lemon over at least 3 turnovers. |
#34 | |||
#35 | |||
#36 | ||
Hit google. Lots of fun clips of runaway diesels on yuotube. Trains, busses, trucks, cars. Good reason to get a snorkel fitted I figure. A hit of CO2 or a rag to shut it down if shutting off the ignition doesn't choke it.
#37 | ||
I think this choking an over revving idea probably doesn't really work because by the time you have realised what is happening you wouldn't have time to find something to block the air supply.Over revving happens quite quickly so there isn't very much thinking and finding time before its all over
#38 | |||
I may be an exception these days but I really don't find the idea of going thru all the dramas of dropping off a car for a repair then getting to work then picking it up much fun anymore regardless of who is paying for it. Yep the law of % say there are a lot of people that don't have a dramas, any problems whatsoever but geez I feel for the people that do. Having said that I have always bought second hand quality vehicles as our primary car. We have had some luck over the years considering we keep them for around 7 years at time. Do not ask about my secondary hobby ones as that is where I lose all my faculties and generally it has something with a Ford badge on it. |
#39 | |||
#40 | ||
3..2..1..
Terri had the same issues, in that the vast majority were perfectly fine. But a few were absolute dogs, and those are the ones that get all the attention.
No one goes online to gush about how perfect their new car is, but if something is wrong then plenty make sure everyone knows about it. Ranger clearly has its own common faults, like every car has. I agree with what was mentioned earlier, people have become used to their new 70k purchase having to make the odd trip back to the dealers for warranty work and that to me is the disappointing bit. These aren't povo pack Asian imports, theyre expensive and from a reputable brand. I notice ford is doing five year warranties on ranger and transit for a limited time. Bit of a carrot to allay some fears? |
#41 | |||
Posts: n/a
If I google it, I find something called a swirl flap which "are small butterfly valves fitted to the intake manifold just before the cylinder head intake ports of many modern automotive diesel engines". (https://en.wikipedia.org/wiki/Swirl_flap) It also then says that the valves are smaller than the runners and therefore lets air pass around them even when closed. So that says to me that those valves aren't designed to block airflow and probably wouldn't stop a runaway. I couldn't find a definitive answer on whether the ranger has a throttlebody-style valve either and whether it stays shut when the car is turned off mid-runaway. There were lots of youtube videos of people blocking the intake themselves, further back than the cylinders and that seemed to kill the engine pretty quickly. I find it hard to believe that the guy from the linked video didn't try switching his car off, if what dunga says is true. I guess I'd just like to know if dunga's advice is because they're familiar enough with the ranger engine to feel comfortable in telling people that those valves will block air flow so just turn the key off, or if their advice is wishful thinking/based on a hunch/etc. Wouldn't it be good to know - conclusively - from someone who works extensively on the rangers' engines and can talk on how to prevent it (if needed), or confirm that it's not needed, or what to do if it ever happens? |
#42 | |||
Posts: n/a
According to burnz you can buy one aftermarket. According to dunga it's not needed because the ranger has intake valves that'll do it itself. |
#43 | |||
Experienced Member
#44 | ||
Not at all i dont know the circumstances why it run away but an engine wont run whithout oxygen maybe he turned the key off maybe he didn't
#45 | ||
I'm sure you are very happy with your trouble free new car,but a lot of people are unhappy because of faults.If you live 10 kms from the dealer and get it fixed quickly you are probably half happy.but if the trip is 100 kms and you don't have your car for a week will you be so cheery?when I look at this forum in5-6 years and you tell us you have clocked over 200,000 without faults then it will be a good vehicle.
#46 | |||
I have a fleet of Rangers, BT50s, and Hiluxes at work. The Rangers and BT50s have done more KM (one 300k +) than the Hiluxes. One of the Hiluxes has caused us the most problems by far. Blown Head gasket, Noisy Diff, failed wheels bearing etc and everytime it is off the road we have to hire a car and it costs us money. The other ones are ok. It doesn't mean all Hiluxes are lemons just that one maybe! But the fact is, as you said, until these Rangers build up a good reputation, which will only come with time, this kind of thing will continue to come up.
Current Rides: PX2 Wildtrak - Daily Driver 1974 XB GT Red Pepper E3 Maloo Black Edition VW Golf GTD - Wifes Weapon ![]() |
#47 | |||
I'm struggling to see how engine oil can make its way through the intercooler system to the intake on a Ranger, must be a lot of oil in there! I'm wondering if these runaways are caused buy overfilling the engine with Oil.
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
#48 | ||
Saw the video of the Ranger runaway today I think on F
acebook but I can't find it now. It was in the USA and it was belching out white smoke like you wouldn't believe and absolutely screaming it's head of for quite a long time. I was expecting it to throw a leg out of bed but it just kept on revving forever
1940 Ford Deluxe Hotrod 1956 Ford Mainline 1958 Ford Customline 2002 Ford Explorer I only drive V8's |
#49 | |||
