#1 | |||
Youth worker
My questions for CF to find it's way into engine components are, 1) speed of production has got to be much longer than casting, pressing or even moulding; 2) strength over the life of the car especially a component like the oil pan where the temps rise and fall consistently... But it's an interesting step by an otherwise recently conservative auto maker!
2007 FPV F6 Typhoon BFII, Neo. Build Number 325 2011 SZ Territory Typhoon Thread: Mr Brooksy's BFII Typhoon Territory Thread: Mrs Brooksy's SZ Territory Resurrection Old Futura thread:
Brooksy's Ex Build |
Parts Interpreter
That's interesting. How does CF go with the heat?
BFMKII XR6 Turbo Sedan
6sp Manual Pedders Coilovers Short Throw Shifter |
Youth worker
I only know that in F1, they use as much CF in non critical components as possible (critically components are like most internals). But then again F1 engine rev higher (more so in the V8, V10 era's) and are under much higher strain. They don't however need to run for 300,000km+.
Kable, it would be interesting to see...
Sandtrap Motorsport
koenisesigg (spelling?) in the early days ran a ford modular engine (modified of course) and was mostly carbon fibre components on said engine
'71 Ford Capri -- 510rwkw Barra powered Capri - new race engine being built Sandtrap Motorsport's BF XR6T wagon -- to tow around the Capri ^^^ www.facebook.com/SandtrapMotorsport |
2 users like this post: |
GT-P With An Ego
See many melted diamonds?
the carbon fibre itself melt point of about 3500°, so it's fine. The resin used to bind it, is what you need to concentrate on. The epoxies go to 300 odd degrees. But if they really wanted high temp and strength, look at carbon ceramic brakes. Carbon fibre in a ceramic binder (instead of the epoxy). I for one welcome our new carbon fibre overlords.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
5 users like this post: |
So many good ideas for stuff , its good ford is experimenting on possible new technology .
if it was to end up on the production line what will be cost effect ? longevity ? |
#7 | |||
They use it in brakes in F1 because they're better at handling high heat. Carbon Ceramic is used in performance road cars because full CF doesn't stop too well when it is relatively cold.
#8 | |||
GT-P With An Ego
https://youtu.be/71wvtEZ-jcI Still look a lot like a mod motor though.
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
The new Cumins engine, for use in Trucks etc. is a composite block. Big weight loss compared to the previous ISX.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
