NeoProbe
Hi guys,
My 1996 Probe (Manual) engine shudders noticeably when I put it under load (anything over 3000 rpms) especially going up hills. I had the engine rebuilt 6 months ago and kept getting a check engine warning code for a faulty EGR valve. I replaced that along with the O2 sensor but the warning light remained. The engine shudder developed a month later. I've taken it to 3 mechanics now and they are all scratching their heads. Has anyone got any idea as to what the problem might be? Neo. |
I'd be checking engine mounts as a possible cause.
Cheers Russ
Cheers Russ
NeoProbe
Thanks Russ. I've also had advice to check the timing belt.
Plug leads for mine.
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel. |
NeoProbe
Thanks Dru. I had the leads replaced when I got the engine rebuild 6 months ago.
Is this a 4 or 6 cylinder ??
Owning a Cougar is like owning a Super Model Good to own but "High Maintenance" ![]() ![]() ![]() 2000 Model Eibach Cougar (Auto) - Now dead & buried ![]() |
NeoProbe
It's the V6. It looks like it may be a CV joint problem.
