Old 27-02-2015, 09:26 AM   #1
Wretched
Render unto Caesar
Wretched's Avatar
Default 2016 Audi R8
The debut of the second-generation Audi R8 was, as are most launches, carefully choreographed to lead up to a spectacular auto-show reveal. We saw teasers. We even rode shotgun in a prototype. But everything spilled onto Twitter and Instagram early, ruining Audi’s plans. We’re sort of okay with that, though, as now we get to tell you about the spectacular second-generation Audi supercar a little early.
To create the new car, Audi started with the platform of the first-gen R8 and modified it into the modern MSS (Modular Sport System) architecture. The bones are shared with the Lamborghini Huracán, but they’re tweaked here for a bit more space and comfort. Compared with the outgoing model, more than 100 pounds have been shed. The R8's backbone is a lightweight aluminum space frame, with the B-pillars, central tunnel, and rear firewall made from carbon-fiber composite materials. At 174.0 inches long, 76.4 inches wide, and 48.8 inches high, it is wider, lower, and a little bit shorter, which gives it slightly more-dramatic proportions. Besides the trunk up front for luggage, there is space behind the front seats designed to hold the proverbial golf bag.
The R8 has been engineered for superior on-track performance, and as a clear indication of its ambitions, it is for the first time available with hard-core performance tires straight from the factory. In standard kit, the tires measure 245/35 up front and 295/35 at the rear—these are fitted to 19-inch wheels. Buyers will be able to upgrade to 20-inch pieces with 245/30 front and 305/30 rear rubber. The water-cooled front differential is unique to the R8 and not fitted to the Lamborghini Huracán, while the electromechanical power steering can be ordered with variable-ratio functionality. Another option is the "magnetic ride" suspension.
Ensconced behind the passenger compartment is an evolution of the previous model's 5.2-liter V-10. The R8 comes to market as the V10 and the V10 Plus; lesser-engined models, as well as an all-electric e-tron, will be added at a later point. The standard V10 model gets 540 horsepower and 398 lb-ft of torque; the mighty V10 Plus is rated at 610 horsepower and 413 lb-ft of torque. The sprint from 0 to 62 mph is said to take 3.5 seconds or 3.2 seconds, and top speed for the cars is rated at an ungoverned 201 or 205 mph. That's faster than ever.
The R8 remains an all-wheel-drive car, with a fully variable front/rear torque distribution from 0 to 100 percent on each axle. Sadly, the lovely gated manual transmission is dead; the new R8 comes exclusively with the DL800 seven-speed "wet" dual-clutch automatic. The driver can select different driving modes including Dynamic and Performance, the latter of which can be set for dry, wet, or snowy conditions to deliver optimal handling. If you want to take it easy and coast along, select Comfort and take advantage of the transmission’s fuel-saving "sailing" function that decouples the driveline when the driver lifts off the accelerator at speeds above 34 mph.
Like the TT, the R8 comes with Audi's "virtual cockpit," although this version is more sophisticated. There is a TFT monitor placed directly in front of the driver; the centrally mounted screen is gone. The flat-bottom steering wheel is fitted with four buttons to select the modes, open the exhaust flaps, and to start and stop the engine. Audi offers different looks and trims for the interior that range from traditional to futuristic.
Outside, the R8 is more angular than the predecessor, and the massive vertical sideblade has been split into two elements. The aesthetic doesn't really take sports-car design to the next level, but it’s contemporary and also doesn't make the outgoing car look dated and frumpy. LED headlights are standard, and there are optional laser lights; they might eventually be offered in the U.S. if the federal government can figure out the regulations. On the European market, they cost about one-third of what BMW is charging for laser lights on the i8.
Down the road, we expect to see another convertible Spyder, an entry-level version powered by a V-6 or a V-8, and two rear-wheel-drive derivatives: the R8 LMS race car and the all-electric R8 e-tron, which will top out at 155 mph and travel up to 280 miles on an electric charge. It should give the BMW i8 plug-in hybrid a run for its money. And perhaps there is even a diesel in the R8's future. To all of this we say, “Bring it on."
http://www.caranddriver.com/news/201...-and-info-news
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 27-02-2015, 09:48 AM   #2
XR Martin
XR Martin's Avatar
Default Re: 2016 Audi R8
Using the school of Porsche design method.
2004 BA wagon RTV project.
Old 27-02-2015, 09:52 AM   #3
DBourne
DBourne's Avatar
Looks great, though I am sad the manual is gone.
But, let's face it, most of the folk who can afford one of these aren't interested in shifting their own gears, so just makes solid business sense I suppose..
I must look like a retard whenever I see a manual one in real person though, that shifter! hhnnngggg
flickr
DBourne is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2015, 10:03 AM   #4
Wretched
Render unto Caesar
Wretched's Avatar
Nothing wrong with a design evolution when the original looks like it does.
Old 27-02-2015, 10:22 AM   #5
Boza
Boza's Avatar
Looks like a bigger audi tt, to me
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2015, 03:21 PM   #6
fgpsi
Looks the same as the 2010 R8, no change
fgpsi is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2015, 03:40 PM   #7
Wretched
Render unto Caesar
Wretched's Avatar
Really? Similar but not the same. There are A LOT of changes.
2010
2016
2010
2016
2010
2016
I am not going to bother with the raft of mechanical and electronic changes that have been made, I think you can read for yourself.
Old 27-02-2015, 04:26 PM   #8
fgpsi
2010
2016
2010
2016
2010
2016
Can't see any differences apart from gimmicks
Old 27-02-2015, 04:44 PM   #9
Wretched
Render unto Caesar
Wretched's Avatar
Old 27-02-2015, 04:57 PM   #10
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
You can lead a horse to water but you can't make it drink.
Back on topic, I'll have one.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2015, 05:13 PM   #11
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Design evolution that doesnt burn current owners.
Hooray!
Audi get it.
That T bar shifter looks so very wrong in that car imo.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
