Qld_Basher
Need to replace the Ignition switch on my ZG Fairlane (Variety Bash vehicle)
1) Cannot remove the steering lock. Have removed the key & lock barrel plus the four retaining screws but despite significant movement the steering lock won't come out. It is a column shift auto so I am wondering if that complicates the issue somehow? Anyone had this issue before? 2) Will likely fit a complete aftermarket ignition switch so need to sort out the wiring. Colours don't seem to match either XA or XB. I have: Yellow. - Battery Yellow with White stripe. - Ignition Red with Blue stripe. - Starter Green with Black stripe. - Accessories Purple. - ??????????? Anyone shed any light on what the purple might be? Thanks in advance, Graham |
According to the schematics I have the Purple goes to Series Resitance which taps off to the Distributor and starter motor.
When the scanner decides to start working again I will post the schematics up for you. Regards Wayne |
Qld_Basher
Thanks Wayne, much appreciated.
Now to find out how to remove the steering lock! Any advice out there? |
Damn, I wish i knew this earlier. Was at dad's and he has the worksop manual for the XB/ZG. If you have no luck in the meantime will pop over on the weekend.
Qld_Basher
I have a Haynes manual but it says "Remove the 4 screws" and then it comes out. But my suspicion is it is more complex for a column shift auto because it won't come out of Park while the steering is locked.
#6 | |||
Workshop manual for XB/ZG can be found here. Regards Wayne |
