Hi everyone not much action on the site lately, well I'm about to change the water in the cougars radiator so what's the easiest way and best coolant to use.
Baz |
Can't help you with this but NEVER you use water you must use proper coolant. However thinking about it underneath should be some sort of plug in the cooling system.
Owning a Cougar is like owning a Super Model Good to own but "High Maintenance" ![]() ![]() ![]() 2000 Model Eibach Cougar (Auto) - Now dead & buried ![]() |
Yes I know about the drain plug and I've got the right coolant, I was interested as to how to get the rest of the coolant out of the engine and heater core,
I thought about putting compressed air in the reservoir to push the water through. Baz |
If you ran the motor when it was cold with the drain plug removed then the system would purge itself just as long as it didn't overheat you would be OK. You might not get ALL of it but certainly most of it.
OR Disconnect one of the hoses and let it drain underneath the car.
I tried getting the drain plug out, no success, both the drain plug and bottom hose difficult to get to, might have to remove the radiator support bracket.
Baz |
Drain plug is very easy to get. You need a big flat head screw driver. It is located on the driver side right opposite to the a/c compressor at the bottom of the radiator. If you got right tools (circlip pliers) then its easy to undo radiator hose clamps. Try not to damage the drain plug. When you put it back, you should take care of torque you apply to tighten. Easy to damage it.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can. Now driving a Lexus RX 450h. Your guess is correct that I am a family man now. ![]() |
#7 | |||
When you use compressed air make sure you do it with care and there is way for the air/coolant to go out.
#8 | |||
Apart from using compressed air, running cold engine carefully for few seconds might be a good idea. Removing thermostat might help as well.
Thanks for advice, I already damaged the plug, could only get short screw driver onto it. so I left it in place until I get a new plug, would repco or autobarn sell plugs for cougars?
Baz |
