Old 29-05-2014, 03:16 PM   #1
malazn mafia
Boss 335
malazn mafia's Avatar
Default Remove Check Engine Light
Have an FG Turbo with a high-flow cat installed. It comes up with a check engine light for emissions. Is there any place in Sydney that could get rid of this for me without a custom tune? Cheers.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 04:02 PM   #2
[Buckets]
[Buckets]'s Avatar
Default Re: Remove Check Engine Light
Most tuners will probably clear it for you but they might charge for it. Buy an ODB2 bluetooth scan tool off ebay and use torque pro on your phone to clear it, or find a mate that has an XCAL
[Buckets] is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 04:48 PM   #3
malazn mafia
Boss 335
Clearing with scan tool or disconnecting battery works temporarily, until all of a sudden the light is on again. I have heard of some people relocating the secondary o2 sensor to fix issue? Apart from that, what would a flash tune be worth?
Old 29-05-2014, 04:56 PM   #4
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
I think you have to either turn the sensor off through the tune or move it so it gets a trick reading. Just clearing the code will only fix the problem until it reads there'd an issue again.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 04:59 PM   #5
malazn mafia
Boss 335
Know anyone who could do that, and not charge an arm and a leg? What is the purpose of the secondary o2 sensor apart from the satisfying the Greens?
Old 29-05-2014, 05:05 PM   #6
FPV GTHO
The second sensor is just for diagnostics afaik, which is why it's just turned off. It still requires a custom tune though. If you've got a high flow cat though there's a risk of iverboosting as well which will likely need a tune to rectify it.
Old 29-05-2014, 05:36 PM   #7
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
trying to do things on the cheap can in many instances cost more than doing it properly in the first place
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 07:00 PM   #8
zilo
BANNED
zilo's Avatar
you can simulate an o2 sensor with some basic electronics.
or just pay for one....
here is an example that I cannot vouch for
http://www.magnumtuning.com/en/detai...ator/ford/f150
it just fools the ecu into thinking all is perfect with the world....
easier to just remove the lamp/led though....
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2014, 12:43 PM   #9
Boza
Boza's Avatar
Ay men to that do it right the first time pay a bit more and you'll have no problems later.
Besides if you mod a car like this do it properly instead of on the cheap and blowing other components later trust me I Know happened to me with My ba xr6t
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2014, 04:27 PM   #10
malazn mafia
Boss 335
Okay, so back to my original question. Anybody who knows a place in sydney, preferably inner west, who can do the job?
Old 30-05-2014, 10:35 PM   #11
red_hotxr6
red_hotxr6's Avatar
Do like penny does, in big bang theory, ignore it...lol
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2014, 11:11 AM   #12
aussie muscle
aussie muscle's Avatar
pull the bulb out?
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2014, 11:55 AM   #13
[Buckets]
[Buckets]'s Avatar
Just disconnect the battery for a while and it'll go away, but it'll keep coming unless you tune it out
