Workshop & Performance
![]() Join Date: Jan 2005
Anyone had this problem? Just wondering if its common and with a common answer....ours might be out of left field but who know
![]() Call the leccy in the morning. Basically car is a trooper, runs like a treat, but no sign of alternator charging. Charge the battery she'll start, run, stop. But no sign of any charging in the middle no matter the battery condition/voltage. Belts all fine. Voltage just drops while in use and keeps heading downhill until it won't start at all.
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1 A stereo that happens to have a XR5 wrapped around it |
RS shop's technician
Done a few alternators or KAs before so yes I'd say it's a fairly common thing to go but only as common as any other car.
Be warned labour charge is high to do the job as you have to take the world apart to get to it!
Advertising removed |
Is it generally fine to put in a second hand one?
Wow, old thread. We ended up sourcing one from a Melbourne wreckers. Turned out the power steer fluid was leaking.....which is conveniently located just above the alternator. Run treat since. Nice thought having a new one or recond, but really, for what the car is worth it's a reach
My 2000 is leaking from the power steering pump also. Quite severely, but I can't ascertain where... do you know the location of yours?
