06-08-2013, 06:19 PM | #1 | ||
XR6T BA 2002
I need to know how tight the caliper bolts are that bolt the whole caliper assembly in one piece with brake pads and all to the bracket at the back and front??
Um in the ford au workshop manual it say caliper retaining bolts 30nm then later on its saying 68 to 92 nm?? WTF check here in the parts data sections its like 115nm which one is it?? please help its getting dark haha |
06-08-2013, 06:43 PM | #2 | ||
Auto Nerd
As a general rule the thicker the diameter, the higher the torque. I normally go about 30nm for the guide pins and up to 90nm for the anchor plate bolts.
Never had a problem. |
06-08-2013, 07:52 PM | #3 | |||
XR6T BA 2002
they bolt the whole assembly? cause i just undid 2 bolts and the whole caliper came off the bracket with pads still in and everything those are the 2 bolts are i can't get a name on or NM spec to match |
06-08-2013, 07:59 PM | #4 | ||
Got Ghia?
The 13mm ones? has the slide pins in them with rubber boot?
Not overly tight, never really torque them, just by feel. Probably somewhere around the 30-40nm i guess.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
06-08-2013, 08:33 PM | #5 | ||
Auto Nerd
Yes, they are the ones. From the specs it looks like 115nm for the fronts and 92nm max for the rears.
07-08-2013, 11:13 AM | #6 | ||||
XR6T BA 2002
if they snap off i know who to PM hahaha Quote:
Stupid falcon manual, its so retarded with its wording I need the factory manual, the ones on ebay look dodge or prob the same as the one i already have thanks heaps for the help!!! |
