Hey guys,
My clutch makes a squeaking noise when it is not engaged. As soon as I put any pressure on the pedal it goes away, also if you lift the pedal it goes away. Someone told me that it was the throw-out bearing touching the fingers of the clutch? Bad design was the reason and no cure was given. It is really annoying. Any ideas?
AU3 XR8 sedan - Manual, Leather, Momo wheel/gear knob |
Mine does the same thing exactly. It's annoying and it's getting worse...
With da Warlords
Yeah Thrust bearing is starting to wear out, It will only get worse
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
Cool. So long as it can be fixed cause it ****** me right off.
Fixed by changing the clutch & spigot bearing. So gearbox has to come out.
871 Productions Filmmaker
Mine does exactly the same, due for a clutch anyway. Good to know it's a common issue!
cheers, Julza
Edge SY MKII Territory TS AWD Blueprint AUIII Falcon XR8 Ute Lightning Strike BA MKII Falcon XR6T http://www.youtube.com/871productions |
#8 | |||
You can't stop the signal
Not a bad idea to do engine rear main seal and gearbox input shaft seal at the same time either
Lol mines just hit 110ks. Clutch still feels strong so ill put up with it for a while longer.
Got Ghia?
Yep, mine squeeks first thing in the morning, disappears after a while.
I'm in no rush to replace it!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
AU II XR8
Mine does it also. The ute makes a squealing noise in the mornings with the clutch peddle in and a fair bit of squeaking with it out, but once it's warmed up its not too bad. The clutch is still strong though, so not too worried about it.
My XR8 sedan also made noises for 5 years, but never failed.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
#12 | ||
my ute does too. put in a new one only lasted about 3 months so then changed clutch and new throw out, it lasted about 30 000k and is doing it again now. never had these problems with my sedan so maybe there is some sort of common issue
23 t-bucket 302w c4 1969 xw falcon 302w t5 1977 lwb f100 351 c6 |
