Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
Lacking Imagination
hey Guys,
I got given a front end upgrade for my AU Fairlane. It came off a BA yet i cannot find any information regarding the discs? Disc Rotors have K388-004C Cast into the front and measure 355mm, Yet they have PBR 2 Piston Calipers. Can you help me out?
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
Race Brakes Sydney
The casting doesn't help me but we do a twin piston kit with 355mm rotors and the rotors are FPV discs but there may also be other kits available as well i would have to get the specs off the disc and see the caliper first.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
Lacking Imagination
![]() ![]() The only Label i can find on the Caliper is a Barcode Sticker that says 'EF8'
Lacking Imagination
Are any of those Pictures Helpful?
Race Brakes Sydney
Are you sure there 355mm they do not look like it?
MATTHEW PEARCE
Lacking Imagination
90% Sure they are...
298 or 325 mm maybe by the looks of them def not 355 mm
![]() This is the difference when compared from a top view, as you can see, not a lot of physical difference between 325 and 355 mm. ![]() .
2015 FGX XR8 5.0 S/C 645 RWKW ![]() Last edited by 05_ENFORCER; 07-02-2013 at 12:23 PM. |
Lacking Imagination
Thanks, Ill check them out tonight and get back to you.
FLOORED, If i wanted a decent set of 325mm Discs to suit, what would they run me?
Race Brakes Sydney
They look like 322mm discs but also check the thickness as these are 28mm and the 325mm thick disc is 32mm thick but that 325mm disc used either a red PBR caliper or a Black BA GT caliper generally.
MATTHEW PEARCE
Lacking Imagination
Minimum Thickness on these says 26mm
298 mm then?
2015 FGX XR8 5.0 S/C 645 RWKW ![]() Last edited by 05_ENFORCER; 07-02-2013 at 01:10 PM. |
#12 | ||
Lacking Imagination
The ones on the Fairlane are 287mm and these things are larger than that. As well as the calipers are larger than AUII/AUIII Items.
I am thinking they are off a Typhoon? cause the guy I got them off has wrecked out a couple of FPV Cars as well as some XR6T's
#13 | ||
From what I have found on late model front brakes:
I haven't researched pre BA models BA, BF, FG 298 mm front std BA FPV 325 mm front BF, FG, XR6T, XR8, G6ET, Territory 322 mm front FPV premo 355 mm front .
2015 FGX XR8 5.0 S/C 645 RWKW ![]() |
#14 | ||
Race Brakes Sydney
The 28mm disc will be either 298mm or 322mm in diamter so just double check tonight to see what you have and let me know in the morning
MATTHEW PEARCE
#15 | ||
Lacking Imagination
No Worries.
Thanks Matt! I will also need Braided Lines to suit the calipers, I am sure you can help me with those as well? Nathan
#16 | ||
Race Brakes Sydney
Sure can mate
MATTHEW PEARCE
#17 | ||
Lacking Imagination
PM Sent
#18 | ||
Lacking Imagination
322x28
Discs have plenty of life in them (measure 27.6mm thick) Will throw on a Good set of Pads and Braided Lines .. ![]()
