Old 30-11-2012, 07:44 PM   #31
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Holden to cull VF Commodore range
Hopefully the build quality improves, the clips on the trim are in most cases stronger the plastic it is holding in, you can easily snap trims, stress mark them or snap off the clip from the trim without much force with a trim removal tool. I worked on two new VE sportwagons this week, had to pull out a lot of trims to hide wires under.
We also noticed the factory battery terminals are loose from factory, you can move them by hand, or you can very easily bend the crap out of the terminal using a 13mm socket to try undo the top nut to add any accessories as the nut is tighter than the terminals which makes them spin, catch on the battery bracket, if you try lever off that the terminal deforms.
Maybe that is why they seem to have a lot of electrical problems?
Old 30-11-2012, 09:20 PM   #32
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
They'll keep the LWB. Makes no sense to axe it from the aust market when it's the basis of the Caprice PPV in the US.
Old 30-11-2012, 09:26 PM   #33
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by TC200six View Post
I thought Holden has too many Commodore models. Right now they have:
Omega
Berlina
Calais
Calais V
S V6
SS
SSV
While Falcon comes in fewer models
XT
G6
G6E
XR6
You're forgetting XR6 Turbo and G6E Turbo. Only 1 less model in the range.
Old 30-11-2012, 09:58 PM   #34
Buntz
Straight Eight
Buntz's Avatar
They're the same trim level, but with more power. I don't think it counts.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2012, 10:04 PM   #35
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
More or less engine options really.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2012, 10:23 PM   #36
Bossxr8
Peter Car
Bossxr8's Avatar
And what is the SS then, compared to SV6. Or Caprice V over Caprice. Caprice V is just a Caprice with a V8.
Old 30-11-2012, 11:26 PM   #37
1TUFFUTE
1TUFFUTE's Avatar
im startled that no one has mentioned that if this was an article about falcon itd be all doom an gloom about holden struggling and commadore was colapsing and all the ussual rubbish. Anyway...i hope they enjoy selling even less rubbish to aussies. Its astonishing how many smucks buy 6cyl commies compared to the competition who actually have great car to sell.
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 08:51 PM   #38
Buntz
Straight Eight
Buntz's Avatar
Hi there.
Welcome to FordBashingForums.
Old 03-12-2012, 10:47 PM   #39
Smoke Pursuit
It's also a good way to profile undesirables.
Something tells me they will keep their LWB sedan... but I doubt the look will change, of maybe only slightly. They still have to provide the U.S. with Caprices.
What I meant was they will only have one caprice variant... They will definitely keep lwb... My guess is it will get a nose job.
Old 07-12-2012, 06:02 PM   #40
Bobman
Regulator
Bobman's Avatar
I think it's a good thing to consolidate models and have fewer.
Ford should do the same and drop the XT in favour of the G6.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
