Old 14-02-2012, 10:57 PM   #1
Antwon
Antwon's Avatar
Default AU running rough - urgent!
Hey guys, just changed the coil pack in the mothers AU2, it all went smoothly (so i thought), until i put it all back together and fired it up and its running very rough, and theres a strong smell of unburnt fuel.
I double checked ive put all the leads back correctly, and also everything else looks fine.
Any ideas would be great, thanks guys.
'96 EL Fairmont Ghia 5L
Antwon is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2012, 12:46 AM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: AU running rough - urgent!
Check it again, two of the leads must be out of order.
Bushbasher
MINE- AUII Forte
Old 15-02-2012, 01:30 AM   #3
Gaz
Got Ghia?
Gaz's Avatar
didn't managed to disconnect the map sensor?
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2012, 09:59 AM   #4
BHDOGS
U got a coil pack of a wreck for cheap and it's ******?
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2012, 10:24 AM   #5
Antwon
Antwon's Avatar
I checked many times that their all in the correct spot, as i said in the original post.
Where abouts is the map sensor??
No i bought a new coil pack, i dont buy any second hand parts..
Old 15-02-2012, 11:18 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
Sounds like it could be a Dud, put the old one back on and see if it is,then go from there .
Originally Posted by Riksta
Old 17-02-2012, 06:00 PM   #7
rowan194
Any update on this OP?
Did you remember to reattach the electrical component (a capacitor if I remember correctly) that has a spade connector that sits under one of the "legs" of the coil pack?
Have you tried disconnecting each spark plug in turn (with engine off) to see if there's any change in the engine note... or in this case, probably more likely, NO change when it's unplugged?
Sounds like you haven't replaced the leads. How old are they? Is it possible you've damaged one when replacing the coil?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 03:03 PM   #8
Antwon
Antwon's Avatar
Got it sorted mate, one of the leads was damaged on the coil pack side, new set of leads and good as gold!
