#61 | ||
I think the people that are implementing the control techniques have done an awesome job tbh.
#62 | ||||
Not sure where you blokes get your info from but there won't be a Ford twin cam engine in COTF Quote:
#63 | |||
No longer a Uni student..
#64 | |||
With the Coyote you are also starting with an engine making 400HP to make you 650 rather then an engine that in stock trim makes ~300HP. |
#65 | |||
#66 | |||
Doesn't matter what engines are used a race team will always strip them down after a certain period.You do know the engines are sealed.Any team can use the same engine components in the Specified Component list. Take a top team eg:888 have to have the engine spec on ther Engine Component Specification list and Usage Log so as all players know what they are using and can buy the said parts from 888 if they want.Specified Components are available to everyone.The top teams are always going to strip them down as soon as the specified time is reached,teams less financial will always push the limits of durability no matter what the rules.No top team is going to give there fellow competitor an advantage.Plenty of the stuff that comes out of those engines is reused after being crack tested ect or sold off.How long does an engine have to last to be cost effective as well as reliable and produce the required amount of torque and horsepower to make it competitive? More than 1000 km around a big hill at full tilt all day tells me they are reliable. |
#67 | |||
LOL. Come on John I know your not that gullible.Good to see you throw it out there though! ![]() ![]() |
#68 | |||
#69 | |||
Arent the NASCAR engines a 5.8L engine? The V8SC engine is a 5L..... |
#70 | |||
A V8SC engine is based on NASCAR technology and parts but using 5l capacity and Fuel Inj. Old school design but they dont get much more reliable and tough than them, and they make enourmous power, certainly enough for parity and the formula. Dollar and durability wise probably as cheap as it gets. We seem to get stuck on a roundabout on this topic. |
#71 | |||
Coyote powered mustang is now being used in Europe in Group 3 racing, the light valve gear and springing of the Coyote make it a generation on from the pushrods and if Mercedes Benz comes on board everything will change... I'm not sure what is planned but the current engines have been with us for many years now and COTF is a great opportunity for use of more economical OEM/SVO parts if they are up to the job... |
#72 | |||
You dig, we stick!
The 5.0 Coyote motor is one of the most efficient motors on the market. Ford claim 100% volumetric efficiency at peak power, and 110% v.e. at peak torque. For a fact it makes more torque per litre than any other naturally aspirated production motor (not including Ferrari's 4.5 litre masterpiece in the F458). This is also achieved without direct injection, which will be introduced in 2013/14. What all this means is it packs a real mean punch. It's a heavy hitter without the cubes. For instance in the states the Mustang 5.0 pulls a smidgeon (about 5rwhp) less power on the same chassis dynos than the LS3 powered Camaro SS. That is practically the same LS3 as what HSV use here (325kW!!). When it comes to aftermarket tuning it responds better as well. Forgetting all the above for a second... the specification, on paper at least, of the L98 6.0 vs 5.0 also suggests the latter does in fact make the same peak torque as the 6.0 but at less rpm, and it also has 37kW more at the top end. In a nutshell the parity rules would be for the 6 litre's benefit only. Have a look at this clip if you get the chance, cheers. Mustang Engine 2011 |
#73 | |||
^^^^^^ That's a really neat video on the new 5.0 and explanation of the technology, they give a reallgood close up view of what the tech is and how it works. If you're wondering how a 5.0 with VCT can out gun a 5.4 Boss, this the video to watch. |
#74 | ||
not here much anymore
Interesting how they've set the air intake up on that FG - flies in the face of what all the 'experts' say on here. Bet i know which one works better too.
2024 F150 XLT
#75 | |||
BOSS 5.4L Enthusiast
Very similar to the Ford Racing intakes for the Mustangs in the states. |
#76 | |||
#77 | |||
#78 | |||
VFII SS UTE
actually they have the same BHP but the ford have 3.90:1 ratio to compensate less torque. holden's run 3.55:1 ratio for parity.. top half of gearbox 5th, 6th are changed for terminal speed.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
#79 | ||
Solution Was Boost 4?, 6 & 8
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
