FPV170
hi xr8 is making clicking sound when starting? Thinking starter motor....? Any helpbe great cheeers???
Think Heavy..
Sounds like a bat flattery !!
________________________________________ 07 BF MkII BOSS 260 XR8 6spd manual! EGO ![]() There's no replacement for displacement!!! ![]() Handling: Bilstein Shocks with King springs all round, Whiteline 27mm front swaybar & 22mm rear adj, upgraded PBR rotors, calipers and braided lines all round with Bendix Ultimate pads. Go Fast Bits: Herrod C.A.I with K&N 4" pod flter, Herrod Helix spacer, Herrod oil breathers, Tridon 72c thermostat, Herrod 2.5" stainless cat back zorst. |
bas afove The clicking is the solenoid caused by your fattery being blat. |
FPV170
tried jumping but to no avail??
335 - STILL THE BOSS ...
Sure the flattery you are using isn't bat as well?
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
I've had batteries so dead that I couldn't jump them. As above bat flattery
#7 | |||
LMFAO ![]() ![]() ![]() ![]() .
2015 FGX XR8 5.0 S/C 645 RWKW ![]() |
Think Heavy..
Might have try buy a new one, process of elimination from there.
FPV170
tried battery in another car started no worries.....
Think Heavy..
Hmmmm, ignition relay...?
Cobblers!
Are you in Park or Neutral?
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
tyr removing the leads from battery & jumpstart with leads disconnected , if it starts then battery is totally fubar, If you have multi meter load test battery put leads from meter to battery terminals & turn key if voltage drups below 10.5 volts battery u/s. if power all good check power to exciter wire on starter should have battery voltage when cranked, if not replace starter relay as it could be burnt out/ still clicking over but no voltage output, if you have battery voltage at exciter wire then starter u/s
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
#13 | |||
Awesome
Location: In my own little world..Everyone here knows me :)
#14 | ||
Formally Kia Chaser
Had this issue recently in my HSV - 3 batteries would not kick it over, but they worked in other cars - car would jump start, but no battery power while driving (only running on alt).
I could get power to the dash, but no crank, But there was no voltage drop on the bat when cranking. Turned out I had a corroded terminal which was preventing enough current flowing to kick the motor over, but enough to run the electrics before cranking....
#15 | ||
Yep, dud cell I reckon.
These newer Fords need a good dose of current to fire them up. Computer says no! .
