Old 23-06-2011, 09:26 PM   #1
jaydee
jaydee's Avatar
Question I want to replace my tail lights with LED's?
My old XC has very dull indicators and brake lights. I really don't want to get run up the rear turning right.
I've checked the globes, cleaned the terminals/lenses etc, even replaced the globes, but still no improvement.
So I was wondering if it's possible to rip out the globes and replace with some nice bright LED's of some sort.
Can it be done, anyone have any ideas please?
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 09:33 PM   #2
Jim Goose
Default Re: I want to replace my tail lights with LED's?
I have seen LED lights with a bayonet fittings to replace the orginal style bulbs on old cars.
But if they are dull id say there is a deeper issue with the old wiring.
Possibly bad earth or resistance in wires due to old age.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 09:33 PM   #3
TheInterceptor
Cruising...
TheInterceptor's Avatar
Sounds like old wiring causing a whole heap of voltage drop.
Id rewire. Unless the lenses themselves are the cause.
Indicators will flash really fast if you install LED since it draws very low power, IE: simulates a blown globe.
If the wiring is fairly new (if youve done a lil resto on it) then disregard.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 09:59 PM   #4
GT-E
GT-E's Avatar
You can get LED replacements for all globs and get a low draw flasher can for the indicators. It would be a great mod and make it look more modern with bright lights.
Fordless.....
GT-E is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 11:21 PM   #5
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
just be careful that the bulbs you replace face straight out and dont point downwards as LEDS are directional. The Escort bulbs point down at 45 degrees and LEDs are useless for it, sadly.
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 11:34 PM   #6
rijruna
I run LEDs for my rearindictors only as they are the weak link on the rear of my '76F100 lights-wise. 2" sq with the 7 element LED brightness is now enough for the brightest day & the fronts? No need, they are big & at eye level for a sedan. The LEDs came from Jaycar & while not cheap initialy, they soon recoup their price in lifespan compared to regular globes. I've had mine for 2-3 yrs & for the same amount of time mightv had to change out 4-5 globes. So, yep good things & no, even tho I only use the 2 rears there was no change in indicator freq. At all. Just make sure, in-store. The first ones I got had 3 dead elements & so did quite a few in that same box. New, all 7 good elements,,, mmmm. Bright enough to leave a slight taste of what a welding flash is like.
Get them, they are worth your money.
Rij
rijruna is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 11:36 PM   #7
jaydee
jaydee's Avatar
You're are spot on the money with this, but re wiring is a job I'd hope to avoid, I hate wiring and electricity.
Good to know I can get some globes, I'll check it out.
jaydee351
4DV8
Old 23-06-2011, 11:38 PM   #8
Revolver
Big Member
Revolver's Avatar
Jaycar electronics had them a few years back. Could start there.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
