Old 27-05-2011, 10:06 PM   #1
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Default MT Radials tubes or not?
Gday,
I have a set of Mickey T Street Radials for the upcoming drag nats and Im being told two different things about if they need inner tubes or not.
The tyres say they need tubes but some people I have asked say no tubes as they will rip the valves out when launching.
So do i need inner tubes or do i not?
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2011, 11:10 PM   #2
Ivan
Default Re: MT Radials tubes or not?
Pretty sure mine dont have tubes.
Ian
Ivan is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2011, 11:47 AM   #3
bluovl 6
bluovl 6's Avatar
NO TUBES i have some american racing tyres that say use tubes but if your tyre spins a bit on the rim when launching you could end up in a nasty situation half track with a flat tyre not fun at all
FG xr6 lightning strike
XF Monza turbo lpg
EA fairmont ghia Carby turbo blow through c4 3.23lsd
bluovl 6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2011, 02:11 PM   #4
blueovalbits
blueovalbits's Avatar
Yep I've had a couple of them turn the valves off the tubes and they go flat real quick...well before half track. (and it's a bad way to lose a run and end up back on the trailer)
Trying to save as many Ford parts from Sims metal as I can!
blueovalbits is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2011, 02:16 PM   #5
dieseltrain79
Street radials are a Tubeless tyre anyway .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2011, 09:39 PM   #6
drcoupe
1975 XB Falcon 500 Coupe
I have the M/T street radials and they are tubeless, they certainly make a big difference to grip.
DR
drcoupe is offline   Reply With Quote Multi-Quote with this Post
