12-05-2011, 05:35 PM | #1 | ||
The 'Stihl' Man
Just wondering if anyone knows either a quick fix or how much a new sensor is for the coolant reservoir? The little bucket icon thing next to the gear selection on the display.
I know my coolant level is good, temp is stable etc and its been on for ages. Had the car serviced today and this is the only thing wrong with it. I can live with it but its a little bit annoying. Im assuming is the plug thing that goes into the side of the tank?
12-05-2011, 05:44 PM | #2 | ||
Critical Thinker
you might wanna just undo the connection at the side of the tank and give it a clean. Sometimes the terminals need a bit of cleaning for better contact. I had this issue before and that's all that was done and no other issues since.
If you are still having issues after this, consider getting the fault codes looked at.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
12-05-2011, 09:39 PM | #3 | ||
If all of the above solutions fail. I have one from either a fairmont Ghia or a Fairlane Ghia which you can have for the right price.
Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
12-05-2011, 09:43 PM | #4 | ||
The 'Stihl' Man
Cheers guys, Ill have a play on saturday.
Anyone know the RRP on the part?
12-05-2011, 09:48 PM | #5 | ||
not here much anymore
Think they may be NLA?
2024 F150 XLT
12-05-2011, 09:54 PM | #6 | ||
they call me Tibbo
iirc it is just two magnets set up like a float in your $shitter... Using needle nose pliers unscrew the bung section to remove the sensor and spray some brake cleaner into the two 'pincers' of the mechanism.. Give it a good wipe and dry and refit... problem solved
14-05-2011, 09:03 AM | #7 | ||
The 'Stihl' Man
Cheers race craft, I assume wd40 would work the same?
14-05-2011, 09:00 PM | #8 | ||
if you lust want the light to stop flashing a 220ohm resistor will do the trick
[SIGPIC][/SIGPIC]
