Old 12-05-2011, 11:44 PM   #1
Antwon
Antwon's Avatar
Default Plenum
Hey guys lookin at doin a few more go fast mods to my car. My question is will a plenum make a difference chasing NA power on a SOHC ticky motor? It will obviously have a little head work, fuel system, tune etc as well.
'96 EL Fairmont Ghia 5L
Antwon is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2011, 11:55 PM   #2
BAGT514
BAGT514's Avatar
Default Re: Plenum
Any NA motor will appreciate a little massaging anywhere that the air changes direction. Making the radiuses as smooth as posible and removing casting flashes & join lines will make the airflow much smoother and yeild small increases in power. Combine that with the other mods you are planning and you will end up with a very efficient motor. If you have some spare time on your hand and a spare intake (cheap from most wrecking yards) - jump in and do it yourself. Don't hog crazy amounts of material out - just clean up what is there
Good luck
Official member of the OCMD Club
"Semi - Silhouette" 2003 BAGT #514
2007 GT500 factory supercharged motor built!
Sensation Blue 2011 FG GT-P # 101
KPM Streetfighter Monster
5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams
FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's
ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches
http://www.fordforums.com.au/showthread.php?t=11408502
BAGT514 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2011, 12:08 AM   #3
Antwon
Antwon's Avatar
Default Re: Plenum
Yeah ive already got a spare BBM, so your saying a mucked around with BBM will be just as good as a plenum?
Old 13-05-2011, 05:37 PM   #4
JC
JC's Avatar
Default Re: Plenum
Do you mean like a turbo plenum? The stock plenum is the shape it is for NA applications - it changes runner length depending on engine speed/vacuum etc to make the most of torque and power through the rev range. Replace that with a box style plenum, and you may gain in the high rev range, but lose heaps down low, or vice versa. Depends what you want.
In a turbo application where power is everywhere, intake runner length etc is less important as the air is forced in everywhere, meaning the design can bet different without much noticeable loss at a particular rev point or throttle position.
Ford Performance Club ACT
Old 13-05-2011, 05:51 PM   #5
dansedgli
dansedgli's Avatar
Default Re: Plenum
A cooler piping blew off last week and it felt pretty good. It didn't feel like it lost a heap of low down power compared it an na one.
You should make more power like the na dohc's do but I havent seen it done on a sohc engine.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
