13-01-2011, 06:23 PM | #1 | ||
Hey guys just wondering what type of remoter booster would be good for my mk2 im running disc brakes allround and where is a good spot or common to mount it ?
17-01-2011, 07:39 AM | #2 | ||
Rally Nut
the twin cam escorts ran a single booster on the LH side front of the engine bay, on rally/race cars when they are using a pedal box I have seen the front one tucked up under the dash on pass side & the other mounted in the back or boot
I run discs all round & use an unboosted pedal box What brakes are you using? |
17-01-2011, 09:31 PM | #3 | ||
yet to decide on brakes id like to run disc on the rear though
18-01-2011, 07:37 AM | #4 | ||
the only other problem is remote boosters are only single circuit i think, so you may need 2.
18-01-2011, 10:18 AM | #5 | ||
Yeh thats is true one for the rear and one for the front any ideas on what type of brakes i should run ?
18-01-2011, 03:24 PM | #6 | ||
Rally Nut
that is so open with a millon questions before the millon options come flooding in
like - what are you using the car for?, min wheel size, budget, soooo many questions need to be asked first as the options are endless on what you have lying around, can get hold of or even what you are prepaired to pay, ie willwood, AP you can buy bigger brake kits off evil bay which convert the front to 5 stud... but then you have the issue of will you run a pedal box? sorry only trying to help, but there are too many options |
