Old 16-01-2011, 12:46 AM   #1
dylanfh
Default Squeeking AU3 front end.
Have a bit of a squeeking noise come from the front of my AU3,originally thought it be the struts because to me sounds like a shagged strut,but i put in some other struts and the noise is still there,any ideas where it could be coming from?.
Im thinking maybe sway bar rubbers or engine mount.
But the strange thing is it gets alot worse and seems to appear when the air cons on.
It sounds exactlty like rubber rubbing against something (not the tyres,its certainly a suspension problem).Ive had someone push up and down on the front of the car when its stationary but no noise.
Any idea whould be great,it gets pretty annoying hearing it.
dylanfh is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 12:49 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
probably the thermos fans.... the ones in the EF at the moment do that and its nothing really....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 12:59 AM   #3
dylanfh
Definatly not the thermo fans,makes no noise at all when car is stationary only when driving,it sounds like a rubber rubbing somewhere,just seems to get worse when air con is on and going over small bumps at the same time.
Old 16-01-2011, 01:58 AM   #4
mik
mik's Avatar
i came across a ZH fairlane that had a squeek in the engine bay somewhere it sounded like loose exhaust flanges , turned out the heater hoses where rubbing against each other when the engine moved/rocked, some cable ties all fixed, i was also thinking water pump and or belt tensioner pulley, possibly alternator? front brakes .wheel bearings?
Old 16-01-2011, 09:57 AM   #5
BuckTooth
Feel the boost
BuckTooth's Avatar
straight up mate, check your ball joints. I had the exact same problem just before christmas.
2005 BA Mk2 XR8 ...... Let the fun begin
Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
BuckTooth is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 01:41 PM   #6
mik
mik's Avatar
what did you do Bucktooth grease the ball joints or replace?
Old 16-01-2011, 03:08 PM   #7
BuckTooth
Feel the boost
BuckTooth's Avatar
just replaced them mate. They're a sealed unit. But not very expensive, i got them from repco.
