Old 05-01-2011, 11:15 PM   #1
liquidforce88
Default world cup Cross member
dose anyone know where i can get a world cup cross member from apart from the uk for a mk2 escort ?
liquidforce88 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 10:38 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
you can get them from
http://classicescortparts.com.au/ind...category_id=31
try here for one off the shelf
I should ask what you are using it for as they aren't that hard to fabricate if you are handing with a welder & grinder, mine took me under a day
cheers
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 12:05 PM   #3
Forte
Just wondering, what are the pro's/con's with the world cup cross member? is it "legal" for on road use? cheers
Forte is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 01:43 PM   #4
Puzzlescort
Rally Nut
the pros simply are they secure the motor a lot better than the standard unit limiting movement
the cons - they tend to vibrate the car a lot more, transferring the harshness as some put it thru the rest of the driveline
are they legal?? I am not expert on that apart from saying all the standard mounting points are used....no modification to body work etc
you would need someone very very switched on to even question one as they look like some standard fitment engine mounts
Old 07-01-2011, 10:39 AM   #5
liquidforce88
Im putting a yb cosworth in my mk2 so just wanted some added strength to the set up hence the use of a world cup cross member cheers
